Can openhab be configurated so it in someway get its device information from hassio so openhab only is a gui client but all device configurations is setup inside hassio config file, so all hassio plugins information shows up in openhab like my Philips hue and ikea tradfri
Is it possible to update this to OpenHAB 2.2? It works up to 2.1 but any later than that results in the same error mentioned in this issue: https://github.com/openhab/openhab-docker/issues/133. Based on that, it seems like it needs to be run with the “-t” option. Do hass.io addons get run with that option or is there a way to make them run with that option?
Can you point us in the right direction? for the life of me I can’t even see how to get docker-compose installed on the hassio image. I have access to the resin install and can run the image manually and can confirm it works, but not sure how to “set” the tty flag via the docker image to run on boot.
This project is exactly what i’m looking for… to hopefully utilize openhab for specific items and hass for others, while hopefully sharing the same z-wave stick.
