Hey, would it be possible to add minidlna and transmission?
Thanks!
B
Thanks for the suggestions. I will add them to the poll as soon as one of the current add-ons in the poll has been created.
Smartthings MQTT bridge implementation. I like this, but I haven’t figured out if I can get it working yet or not…
Another vote for getting tellstick duo to work. Only thing stopping me from using this exclusively (y)
Could anyone make a Profibus or Profinet add on?
This could be a very cheap data historian!
Hey guys as I’m not a programmer but a privacy freak I keep everything internal and would need something or better exactly this running https://github.com/sezuan/uploadr/blob/master/README.md
But I dunno how to build an admin with this
Note that this needs python 2.7 as I got errors with pyrhon3 but with venv it should work but as I said I don’t know how to archive this. Is here someone who could build an adding for this?
Thanks.
Now if my Home assistant address is with duckdns and also letsencrypt will it still work?
@Dayve67 Yes that would work. Just remember to use https:// in the configured URL.
Perfect that worked. Just had a problem with my password. json dont like characters in the password.
Thank you
I still have 1.0.3 installed. How do i trigger the update?
@Maaniac Just go to the add-on “store”, in the top right, hit the refresh button. Wait a couple of seconds and the update will pop-up!
Saw someone on twitter suggested Floorplan.
I’d like that one too.
You mean the custom floorplan by @pkozul?
If so I can confirm it works great with hassio already…
You just need to create a www dir in your config dir. All the custom stuff goes in there.
Using the samba addon helps.
I’ve received the suggestion multiple times already.
Agreed. Nevertheless, I could be a run-once add-on that does this for you?
Yes, but at top of this thread you want us to suggest things that is not in the poll, and i could not see anyone in this thread have suggested it before.
It’s a nice idea - I never really thought about using a run-once add-on to install. I will keep this in mind ![]()
You’d need to be careful that running a second time by mistake does not trash modified files… and with floorplan there is likely to be modified files. Its not a simple as install the custom files and dropping in a SVG of the floorplan.
