Thanks for that information. Looks like I have another issues now, I removed homeassistsnt from the home app on iOS and now when I attempt to re-add it the home app isn’t detecting homeassistant.
Two reasons why Homebridge may not be discoverable:
Homebridge server thinks it’s been paired with, but iOS thinks otherwise. Fix: deleted persist/ directory which is in your
config/homebridge
directory and restart the add-on. -
iOS device has gotten your Homebridge username (looks like a MAC address) “stuck” somehow, where it’s in the database but inactive. Fix: change your username in the “bridge” section of
/config/homebridge/config.json
to be some new value and restart the add-on.
So deleting the persist/ directory did the trick. Back up and working again.
You’re welcome
I’m happy it worked for you.
FYI: I’ve created a topic on this forum specifically for my repository: Repository: Community Hass.io Add-ons
Since I’ve started developing multiple add-ons, I thought it would be more sensible to create my own topic to keep things out of topics like this one.
What types of supported_types do it support? Do it exist any list?
Please check the documentation here:
Thank you very much for the updated Homebridge plugin! It works like a charm!
For future updates, please check this topic: Repository: Community Hass.io Add-ons
Hello guys!
Just a heads up: new version arrived: https://github.com/home-assistant/homebridge-homeassistant/releases/tag/2.3.0?platform=hootsuite
Thanks!
after upgrading to this version it totaly broke my homekit
can’t fix it all day long. I see the bridge but when i adding it i get: couldn’t add (Home couldn’t connect to this accessory)
Tried deleting persist and cached accessories, without luck. tried to reinstall as well - the same.
what it can be?
Hello friend!
Try this:
SFAB
1d
I’ve just encountered an issue with the homebridge addon. Suddenly none of my devices showed up in Homekit anymore.
While checking the logs of the homebridge addon I found a line regarding the default device visibility. I’ve fixed the issue by adding
“default_visibility”: “visible”
to the platform section in config.json:
“platforms”: [
“platform”: “HomeAssistant”,
“name”: “HomeAssistant”,
“host”: “http://172.17.0.1:8123”,
“password”: “”,
“default_visibility”: “visible”,
“supported_types”: [
“binary_sensor”,
“climate”,
“cover”,
“device_tracker”,
“fan”,
“group”,
“input_boolean”,
“light”,
“lock”,
“media_player”,
“scene”,
“sensor”,
“switch”
Now the addon works fine again.
No, it doesn’t help. I have the default_visibility already in my config.json, deleted the persist and accessories folder, still getting: Couldn’t add Home Assistant
Home couldn’t connect to this accessory.
Installed the hassio addon, but i don’t see the homebridge in Home app (other devices looks ok)
Tried bounjour browser, also not showing.
using netstat I see the port is listening on ipv4 only (with previous verision when it worked it was listening on ipv6 only)
pi@raspberrypi:~ $ netstat -an | grep 51826
tcp 0 0 0.0.0.0:51826 0.0.0.0:* LISTEN
also i see in hassio plugins homebridge panel that no network port appears at all:
docker container looks like this:
pi@raspberrypi:~ $ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
da9206497277 d89827df/armhf-addon-homebridge "/usr/bin/entry.sh..." 15 minutes ago Up 14 minutes addon_d89827df_homebridge
can you suggest what can i check?
Looking at your command line, it seems like you have installed Hass.io manually (generic Linux install version?)
In that case, it is currently a known issue. Please see our GitHub repo’s issue trackers for more information.
yes, that’s correct.
as far i can see you solved it by adding configuration option avahi-interfaces ?
any chance you can share the steps you did?
do you start the homebridge docker manually? if yes, can you please share your command?
Thanks!
No, it is not started manually, it is a Hass.io add-on and you should let Hass.io manage it. So do not manual start.
Secondly, there is nothing solved. It is a known issue, planned to be fixed in the v1.1.0 release.
Please take a look at our issue trackers on GitHub.
ok, after digging a bit, i removed avahi service from my linux host and now the homebridge appears correct in my Home app.
But when i trying to connect, after entering the code, i’m getting:
Tried removing persist and accessories folders and restarting, still not good, also tried on different iphone as well, got the same.
So not seeing Homeassistant as an option anymore when adding accessory from the Home app. removed persist as well. Using homebridge 1.0.3
