Representing controls as individual devices
Hi, I’m setting up a dual plug using localtuya and it seems to only allow configuring it as a single device with two controls (“plug 1 on/off”, “plug 2 on/off”)
However, the uses for these two plugs are completely independent and the fact that they are part of the same physical device is an implementation detail that I want to hide. So, I need to have plug 1 and plug 2 represented as first-class “devices” instead of “controls/entities” on the same device.
I imagine there’s probably a way to have “virtual devices” or dummy switches or something like that, but I’m new to HA, so I need to be enlightened.
Any ideas? Thanks!
EDIT: actually, are “entities” the way to think about first-class devices in HA?
Yes that.
perfect, thank you, apologies for the noob question.
Cheers
No problem. Best to avoid devices altogether.
Interesting, that is very smart and I’ll keep it in mind as I start to build up my automations.
I’m coming from HomeKit+Homebridge, where there is no such concept - this level of control is exactly why I’m migrating to HA! :slight_smile:
