Purchased one of these for Amazon, and apparently were released December 2023 (from the low serial numbers I got, can confirm as pretty early poor software quality):
I had hoped it was Tuya based (as many are), but sadly it was not. I tried their built in app, and like others have reported, it crashes and unusable. It’s using some IoT Cloud service from China I had not heard of before. (If I reinstall it, I will note it here)
Upon removal, found very clearly it’s using an ESP8266-07S module surprisingly with an external antenna taped to the back of the unit so it’s not on the bottom for better signal. This actually quite nice and could allow later for a custom external antenna for even better coverage.
THIS IS AT YOUR OWN RISK. I AM NOT RESPONSIBLE FOR DAMAGE TO YOU OR YOUR PROPERTY
Here’s a messy pic of the header pins:
GPIO0 is the front toggle button.
FLASHING:
- Unplug power before opening
- Hold the front toggle button in while powering up the board with your favorite TTL converter
- I used 3.3V to power it
- Once powered up and flashing, you can release the toggle button
What’s working:
- Red / Green Status LEDs
- Front Toggle Button
- Water reservoir float switch
- Blower Fan
- Fogger transducer
What’s not working:
- The potentiometer appears to be connected through an opamp to the ADC line of the ESP8266, but did not observe any voltage change while turning it. Not sure what it does as not in the documentation either. I suspect it was used for setting the output strength, but just a hypothesis from testing with the originally flashed unit.
Notes:
- I do not recommend running the transducer without the blower running
- It uses a series of transistors internally so doesn’t look like you can turn the blower or the transducer on unless the float switch detects water (turning upside can be used for testing)
- It’s surprisingly easy to work on and open up, only 4 screws. The blower is easy to replace and a standard size. Transducer also looks easy to replace.
I believe this is the streamlined version of my ESPHome configuration:
substitutions:
disp_name: "humidifier01"
esphome:
platform: ESP8266
board: esp07s
time:
- platform: homeassistant
on_time_sync:
then:
- logger.log: "Synchronized system clock"
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: !secret esphome_api_key
ota:
password: !secret esphome_humidifer01_password
wifi:
ssid: !secret esphome_wifi_ssid
password: !secret esphome_wifi_password
domain: !secret esphome_domain
power_save_mode: NONE
fast_connect: False
ap:
ssid: !secret esphome_ap_ssid
password: !secret esphome_ap_password
captive_portal:
switch:
- platform: gpio
pin: GPIO15
on_turn_on:
- switch.turn_on: rel_2
on_turn_off:
- switch.turn_off: rel_2
- platform: gpio
name: "Fogger Transducer"
pin: GPIO4
on_turn_on:
- switch.turn_on: rel_1
on_turn_off:
- switch.turn_off: rel_1
output:
- id: led_water_out
platform: gpio
pin: GPIO16
inverted: true
light:
- platform: binary
name: "Water Reservoir Empty"
output: led_water_out
- platform: status_led
pin:
number: GPIO2
inverted: false
disabled_by_default: true
binary_sensor:
- platform: gpio
pin:
number: GPIO0
inverted: true
on_press:
then:
- switch.toggle: rel_1
- platform: gpio
name: "Water Reservoir"
device_class: problem
pin:
number: GPIO13
inverted: true
on_state:
then:
- output.turn_on: led_water_out
- light.turn_off: esp8266_status_led
on_release:
then:
- light.turn_on: esp8266_status_led
When the unit powers up after being flashed, it should start with a Green LED that flashes. Once it’s connected to WiFi, it should stay solid Green unless it runs out of water and turns Red. I set it up as well so if the fan or transducer turn on, it turns the other on. Probably could do a script or other ways to make the cleaner. If you press the front button, it will turn toggle the unit fogger/fan between on and off.
If for some reason anyone else is crazy enough to try this, and you figure out anything else, please let me know Several of the GPIO lines are connected but unsure what are being used for as some parts were tricky to trace.
