Hi there!
I have an older Home Ventilation System that I am trying to automate. I managed the hardware part with a Z Wave Dimmer (Quobino Flush 1-10V) and can control the fan speeds in Home Assistant from 0-100% using the slider.
Now I am trying to set up a clever automation and since I am very new to HA I have no idea how!
I managed to set up a simple “Up” and “Down” automation based on a Humidity Sensor crossing certain thresholds, but this isn’t working the way I want it to.
First issue is, that I can’t set any percentages. I can only select “brighter” or “dimmer”. It also isn’t very dynamic.
Since I want to eventually have this working with 3 CO2 or VoC Sensors I need something a little more complex I’m afraid.
My idea:
The “0-10V Dimmer” should regulate in a bracket between 20 and 80% of it’s range. The “Baseline” should be 40% (that is 120m^3 of airflow).
Based on the current humidity (later CO2) readout it should ramp up slowly until the Sensor reading starts dropping and then slowly ramp down again.
I hope someone can help me with this. Thanks!
Ok, so a tiny Update…
I figured some of this out myself. It turns out that the “brightness _increase” was the wrong choice.
I use turn_on instead and then I can set a value. This is already big progress for me.
Now…at my current skill-level I would have to set up about 10 separate automations, 5 for corresponding “up” values and 5 for “down”. It would be easier and prettier if I could somehow combine this.
The idea: create a list of matching pairs…
Example:
CO2 400ppm - 20% Ventilation
CO2 600ppm - 40% Ventilation
CO2 800ppm - 50% Ventilation
CO2 1000ppm - 60% Ventilation
CO2 1200ppm - 80% Ventilation
CO2 1400ppm - 100% Ventilation
How would I go about writing this?
The triggers and actions are simple (read sensor value XX and set light_on XX)
It feels like I’m talking to myself here, but anyway…managed to get this working in a rather convoluted but functional way. I only have one CO2 Sensor so far, two more are arriving tomorrow. Will have to play around with placement and thresholds a bit, but pretty happy with the automation so far!
Here’s the resulting yaml if anyone is interested
- id: ‘1659476482236’
alias: Lüftung 50
description: ‘’
- platform: device
device_id: 58b90fa4e8b50efd008c8c556b7270b0
domain: climate
entity_id: climate.schlafzimmer
type: current_humidity_changed
above: 55
below: 60
- type: humidity
platform: device
device_id: 43498c628e6ce8314085af0f139e0162
entity_id: sensor.wandthermostat_badezimmer_humidity
domain: sensor
above: 55
below: 60
- type: carbon_dioxide
platform: device
device_id: 74a5a83b2fdaea03c15c944e0e2df9cf
entity_id: sensor.home_wohnzimmer_co2
domain: sensor
above: 800
below: 1000
condition: []
- type: turn_on
device_id: 6fd1219f46b183aa2e3238e1bc3c1f72
entity_id: light.flush_dimmer_0_10v
domain: light
brightness_pct: 50
mode: single
- id: ‘1659476857347’
alias: Lüftung 40
description: ‘’
- platform: device
domain: climate
below: 55
- type: humidity
platform: device
domain: sensor
below: 55
platform: device
domain: sensor
below: 800
above: 600
condition: []
- type: turn_on
domain: light
brightness_pct: 40
mode: single
- id: ‘1659705774041’
alias: Lüftung 60
description: ‘’
- platform: device
domain: climate
above: 60
- type: humidity
platform: device
domain: sensor
above: 60
platform: device
domain: sensor
above: 1000
below: 1400
condition: []
- type: turn_on
domain: light
brightness_pct: 60
mode: single
- id: ‘1659710845252’
alias: Lüftung 30
description: ‘’
- type: humidity
platform: device
domain: sensor
below: 55
- platform: device
domain: climate
below: 55
platform: device
domain: sensor
below: 600
above: 500
condition: []
- type: turn_on
domain: light
brightness_pct: 30
mode: single
- id: ‘1659711015246’
alias: Lüftung 20
description: ‘’
- platform: device
domain: climate
below: 55
condition:
- type: is_humidity
condition: device
domain: sensor
below: 55
- type: is_carbon_dioxide
condition: device
domain: sensor
below: 500
- type: turn_on
domain: light
brightness_pct: 20
mode: single
- id: ‘1659711621994’
alias: Lüftung 80
description: ‘’
- platform: device
domain: climate
above: 60
- type: humidity
platform: device
domain: sensor
above: 70
platform: device
domain: sensor
above: 1400
condition: []
- type: turn_on
domain: light
brightness_pct: 80
mode: single
I have made some changes since the origianl automation had some issues. Here is the current code:
alias: Lüftung 50
description: ‘’
- platform: device
domain: climate
above: 60
- type: humidity
platform: device
domain: sensor
above: 60
platform: device
domain: sensor
above: 800
below: 1000
platform: device
device_id: 6554dfa312146774ee689699e8a2e41a
entity_id: sensor.abluft_co2
domain: sensor
above: 800
below: 1000
platform: device
device_id: 687dc0ca4041da367d7a39de8573e887
entity_id: sensor.home_wohnzimmer_obergeschoss_co2
domain: sensor
above: 800
below: 1000
condition: []
- type: turn_on
domain: light
brightness_pct: 50
mode: single
alias: Lüftung 40
description: ‘’
- platform: device
domain: climate
below: 60
- type: humidity
platform: device
domain: sensor
below: 60
platform: device
domain: sensor
below: 800
above: 600
platform: device
domain: sensor
above: 600
below: 800
platform: device
domain: sensor
above: 600
below: 800
condition: []
- type: turn_on
domain: light
brightness_pct: 40
mode: single
alias: Lüftung 60
description: ‘’
- platform: device
domain: climate
above: 65
- type: humidity
platform: device
domain: sensor
above: 65
platform: device
domain: sensor
above: 1000
below: 1400
platform: device
domain: sensor
above: 1000
below: 1400
platform: device
domain: sensor
above: 1000
below: 1400
condition: []
- type: turn_on
domain: light
brightness_pct: 60
mode: single
alias: Lüftung 30
description: ‘’
- type: humidity
platform: device
domain: sensor
below: 60
- platform: device
domain: climate
below: 60
platform: device
domain: sensor
below: 600
above: 500
condition:
condition: device
domain: sensor
above: 500
below: 600
condition: device
domain: sensor
above: 500
below: 600
- type: turn_on
domain: light
brightness_pct: 30
mode: single
alias: Lüftung 20
description: ‘’
platform: device
domain: sensor
below: 500
condition:
condition: device
domain: sensor
below: 500
condition: device
domain: sensor
below: 500
- type: is_humidity
condition: device
domain: sensor
below: 60
- type: is_humidity
condition: device
device_id: 1f258b16513f9f455882975ea05a8d49
entity_id: sensor.schlafzimmer_heizung_humidity
domain: sensor
below: 60
- type: turn_on
domain: light
brightness_pct: 20
mode: single
alias: Lüftung 80
description: ‘’
- platform: device
domain: climate
above: 70
- type: humidity
platform: device
domain: sensor
above: 70
platform: device
domain: sensor
above: 1400
platform: device
domain: sensor
above: 1400
platform: device
domain: sensor
above: 1400
condition: []
- type: turn_on
domain: light
brightness_pct: 80
mode: single
- id: ‘1659966748946’
alias: Node Dead?
description: ‘’
- platform: device
domain: zwave_js
type: state.node_status
entity_id: sensor.node_2_node_status
to: dead
condition: []
- service: notify.mobile_app_pixel_6
message: Flush Dimmer Dead
title: Node Died
mode: single
This still needs a lot of work and streamlining, but seems to be functioning fine so far. I doesn’t have any safeguards in place for outdoor CO2 being high or relative humidity being problematic, so please be aware of these limitations. As always, I am a complete novice, any help would be extremely welcome!
