Good day,
I am new to Home Assistant and have integrated my Solar system into Home Assistant via MQTT.
I would like to have an automation setup which would allow my pool pump to only switch on when the solar batteries are charging (more than 50Watts charging) and the battery state of charge is above 74% and for the pool pump to turn off as soon as more than 700Watts of solar battery power is consumed.
I have created the following automations which are working to some extent. My challenge is that the automation to turn the pool pump on only trigger when the value of 50Watts charging is crossed and does not trigger when the charging is above 50Watt whilst the solar battery state of charge is above 74%
The automation for the switching off of the pool pump is working as required.
Could the members kindly please assist me to fine-tune the automation to turn the pool pump on when the solar batteries are charging (more than 50Watts charging)
Pool Pump on Automation YAML:
alias: Pool Pump on if Battery Power is >50Watt & SoC >75
description: Turn on Pool Pump if Battery Power is >50Watt & Battery SoC >75
- platform: numeric_state
entity_id:
- sensor.battery_power
above: "50"
condition:
- condition: sun
after: sunrise
- condition: numeric_state
entity_id: sensor.battery_state_of_charge
above: "74"
- condition: sun
before: sunset
- type: turn_on
device_id: dfdecabb5649013065514d6c74b5f481
entity_id: switch.sonoff_10017447ea
domain: switch
mode: single
Pool Pump off Automation YAML:
alias: Pool Pump off if Battery Power is >-700Watt
description: Turn off Pool Pump if Battery Power is >-700Watt
entity_id:
above: -700
condition:
- condition: sun
after: sunrise
- condition: sun
before: sunset
- type: turn_off
domain: switch
mode: single
Any assistance would be greatly appreciated.
