TL;DR - I am trying to create a new dashboard using UI-Lovelace-Minimalist. I am able to register the dashboard and it appears in the sidebar, but any attempt to activate it displays the default dashboard. I suspect that HomeAssistant is generating the wrong Lovelace URL.
Specifics:
Installed Ui-Lovelace-Minimalist (ULM) via HACS. Sample dashboards show up in the sideboard and load correctly.
Using same folder as the sample dashboards, created a copy of the adaptive-dash and renamed dashboard configuration to ulm-dev/ulm-dev.yaml.
Modified ulm-dev.yaml and changes the views path attribute to “main” and various combinations thereof.
modified configuration.yaml and added the following entry:
lovelace:
mode: storage
dashboards:
ulm-dev:
mode: yaml
title: ULM Dev
icon: mdi:flower
show_in_sidebar: true
filename: ui_lovelace-minimalist/dashboard/ulm-dev/ulm-dev.yaml
- Restarted HomeAssistant
Results:
- New dashboard appears in sidebar.
- Activating it results in loading my default (Overview) dashboard. URL is /ulm-dev/0
Any help would be much appreciated. I’ve spent hours of google searches and configuration attempts without any success. My guess is that the generated URL is incorrect.
Thx
-steve
