Request for Shopping List service
I’m using the Shopping List integration since a few weeks. I found a script that creates a sensor that includes all the items that are on the list. When I’m at my local store, Home Assistant sends me my Shopping List. Real handy!
When I’m back home I have to clear my list one by one, unfortunately. There is no service to clear the complete list at once. I would like to have this service.
I would use it in combination with actionable push notifications. So when Home Assistant sends me my shopping list, I can push a button ‘Empty’, which ‘completes’/clears my shopping list.
If there’s already another way to easily clear my shopping list items all at once, please let me know! If not, I would realy love to have a new service for this.
Have an automation that runs from a trigger boolean that runs a script
the script checks the bit and then runs to remove the last item, it then checks the length of the list and resets the bit if the length is zero, then runs itself at the end
It then …
You get the idea
Thanks for the idea. But unfortunately I’m not able to code such a script…
Okay, but everyone starts at that level, they have to learn and the best way to learn is by trying.
Read the docs on : -
  1. YAML
  2. input_boolean
  3. input_list
  4. automations
  5. scripts
    1. text editors
    1. splitting your configuration files up
When you run into difficulties you can come back for help, but so far, you have made very little effort
Can you clarify how you would use input_booleans in this situation? I don’t want to create multiple input booleans for common items I want to put on my shopping list. I just want an easy way to clear all items of my shopping list. I don’t think your idea covers that.
Okay, creating entities so that you can interact with them is how you work with HA.
Eg. What temperature do you want to turn your boiler off at because it has reached temperature - take it from an input_number
When should this shopping list be cleared, when you have told it to clear by setting an input_boolean
When do you want your music to come on in the morning, set it by using an input_datetime
These are the bread and butter of HA
In this case as scripts can’t do loops, I’m suggesting it be set to trigger your automation (normally door is detected open, it’s dark outside so turn the light on) this automation just calls a script to reduce the list (as you would) by one. How long is the list? 12, okay so leave the boolean on and call the script again, repeat 12 times, how long is the list? 0 okay turn the boolean off and don’t call the script. Et Voila!
If you only interact with HA through integrations then you are only using 2& of what you could be doing. AND waiting years for someone else to build an integration that turns your music off when you turn your TV on and turns the lights down low because it’s after 18:00
Read some of the other posts about what other people are doing
Roll your sleeves up and dig in, it’s very satisfying when you are at home and someone says “hey ALL the lights in your house turned down at 22:00 together - how did you do that?”
@Mutt
I don’t think you understand what the OP is asking for. Doesn’t matter what automation you write if the service shopping_list.clear or whatever doesn’t exist. OP is asking for that feature to be added. That’s what the Feature Requests forum is for.
I have been thinking of trying out ourgroceries. It has a custom component https://github.com/ljmerza/ha-our-groceries/tree/master/custom_components/ourgroceries, and work is under way to introduce so services into HA. https://github.com/ljmerza/py-our-groceries/
No, I get that entirely.
However what I’m pointing out is that it is so trivial to do yourself that no-one (in the current devs group) is going to spend any time on it as they have bigger fish to fry.
There are so many things wrong, part of being a user is knowing what features to avoid. Don’t get me wrong HA is a phenomenal body of work and it’s moving in the right direction, but the automation editor (for example) is neither use nor ornament. The documentation is (though recently reduced) still huge and keeping it up to date with developments must be a nightmare.
I’ve seen your posts I know you know where HA is on the development plan. So any bits we could do ourselves, we should.
I was simply pointing out why I wouldn’t vote for it as I have different priorities.
So if someone wants to do the work and pass it in through the devs the power to them. But I think time would be better spent elsewhere.
Nil point
Another good one is Grocy. There is a HassIO add-on for it or it can be run as a normal Docker container. I just can’t get my girlfriend to use it…
I thought Grocy was a bit overkill.
The cool thing with it is the ability to use automations to add specific items to your shopping list. I read an article somewhere on the web about an automation to subtract a dishwasher tablet each time the dishwasher ran and then add a box of them once the stocks were low enough. Seemed pretty awesome. I haven’t looked into the normal HA shopping list too much but it can likely do the same thing I guess
That would be cool, and your post is poignant, given we ran out of tablets last night! They are written on the blackboard at home, but that doesn’t really do any automations. In fact it is bloody useless when I am at the supermarket. I could take a photo with my phone, but I forget to do that too.
I might look at grocy again.
Found it:
Thanks.
One quick question about grocy. To use it out of your home, does it need access to the grocy server running at home? ie a hole in your firewall?
Personally I use ToDoist for shared lists and then a handful of text variable IFTTTs ‘Hey Google, add $ to X list’ - where X is different in each IFTTT recipe. IE grocery, lowes, costco, target, etc…
I FULLY realize it’s not HA, but easiest way I’ve found to allow multiple people to use multiple lists concurrently - then it’s just clicking on the item in the list in the todoist app on our phone while shopping to remove.
Caveat - we do have to pay a bit a year to get the ‘shared’ list feature - but the ease is worth it- and allows our nanny and others to easily add via the google home in the kitchen.
Downside is all the stuff the kids have figured out how to add… someout ended up with ‘billy joe bob spongepants head’ on the list at one point… :man_shrugging:
If someone has a pure-play HA way that’s easier than this, happy to implement, but until then, $30 a year (or whatever it is) is worth it to me for the ease / ‘it just works’ of this setup.
I’m using the HassIO add-on which has Ingress enabled, so for me it’s a sidebar tab. I guess if you were using the stand-alone version you should be able to integrate as an iFrame to end up with the same outcome. Either way you can view it when out of the house
Thanks for the tips about Grocy. But it’s still not a solution for a quick way to clear all the items of the Shopping List.
@Mutt: You act like I don’t have any knowledge about Home Assistant, that’s not true. I’m just asking for a feature request, and not someone who thinks he got more knowledge of HA than someone else. Please think twice before you post such a long contemptuous story. This forum is to help each other instead of bringing someone down if you think they have less knowledge than you.
Ang again I would like to point out; I just asked for a feature request of a new shopping list service to clear all items on the shopping list.
Your answer was not realy an answer to my question (if there’s an easy way to clear all the items on my shopping list / how to use an input_boolean to clear the shopping list), because it’s not possible to use an input_boolean to clear the shopping list without this shopping list service I’m requesting.
Yes.
Read my earlier replies.
It was not meant to be definitive is was meant to suggest a possible alternate means of action, one (possibly) where you write some code.
