Request for yeedi vacuum integration
Any chance we could get working yeedi vacuum integration somehow? I bought a Yeedi Mop Station and I love it!
As I understand Yeedi is a sister company of ecovacs; I have attempted to set up the vacuum through the ecovacs integration but there’s no dice.
I second that!
Me too! I love it!
so as I understand Yeedi and Ecovacs are the same, same mfg, sister companies, hardware is the same, i would assume the vac firmware is different. Hopefully this wouldn’t be too hard to setup
Looking for this as well
I second that!
I’ll throw another hat into the ring as someone that would like this intergration.
i follow this thread :smiley:
When using Google assitance, the authentication happend at user-login
hope this help. :slight_smile:
Yes please, been looking to integrate my yeedi vac for a while now.
While I was tinkering around with it I found that you can create an ecovacs account and pair a yeedi vac to the ecovacs app. You can even use the ecovacs home assitant integration and your yeedi vac will show up. Issue is, that the app does not support to control the vac and therefore home assistant is also unable to control the vacuum.
But it shows that ecovacs and yeedi a closely related, which gives me hopes that someone will be able to create an integration.
is there any progress on the yeedi integration?
I don’t think so, unfortunately I don’t have the skill to develope and thus far no one did as it seems. I hope that someone will eventually do it.
Hi guys,
i wanted to share my configuration to integrate with the Yeedi.
With the new 2023.01 update of Home Assistant we can use the Google Assistant SDK. I normally don’t use Google but unfortunately it is the easiest way to control the vacuum robot via Home Assistant.
So I paired the yeedi vacuum in the Google Home App.
I then followed this guide to setup the Google Assistant SDK. That way I can send text commands to Google Assistant.
Next and final step was to add a vacuum template integration in Home Assistant:
vacuum:
    vacuums:
      yeedi:
        start:
          - service: google_assistant_sdk.send_text_command
              command: Start yeedi
        return_to_base:
              command: yeedi back to dock
        stop:
              command: Stop yeedi
Together with the Mushroom Vacuum Card it can look something like this:
The biggest flaw is defintily the missing callback. So there is currently no way to get a status of the yeedi back into Home Assistant. That would be so awesome. And as far as I know start, stop and dock are currently the only supported actions.
Maybe this helps someone.
Awesome, Marc - thank you very much for sharing this approach! Works like a charm for me.
On https://assistant.google.com/services/a/uid/000000a63cfca11c, some more potential commands are listed (charging, pausing, and status for example).
This is now possible with:
Does anybody had it working with the new callback solution?
Would be really great to get it working with a response.
I think the ioBroker community has an integration for this.
Someone skilled enough could possibly use this to create something for home assistant?
Keeping an eye out on this for potential future developments; as I have two Yeedi vac 2 pro and would love to get them into Home Assistant. Sadly don’t have the skillset to contribute to developing it myself.
The nodejs implementation which iobroker uses would be interessting for implementation:
I’m no coder so it would be much harder to get it runnning…
No coder here which could a have a look on it?
Any news about this implementation for Yeedi in HomeAssistant?
