how do I add the yeedi nodered nodes to my homeassistant?
Hi @Tomschin, how can we integrate your project in homeassistant?
Because I have imported your json stringâŚand than?
If you have installed NodeRed and imported my code. You should see the buttons in the picture above.
Doubleclick on Yeedi in the center of the flows. (The button above the big yellow box.)
Enter your ecovas-account information.
Deploy the changes in NodeRed.
Now the buttons like Start and Pause should be sent to your vacuum.
Then go to Settings/Devices & service/Node-RED Companion/1 Device there you should find all the controls for your device.
I donât get the Yeedi or the large yellow box when I import?
I have to assume something else is missing yet.
Did you have to setup that up before creating the rest of this?
Where are those instructions?
No. You just need a running instance of âhome assistantâ and the add-on âNode-REDâ installed. Then import the code. Thats all. Thats the complete instruction.
Hi Thomas, Many thanks for your explanations and work.
It seems that the code that you shared in your earlier posts don´t show the result that you shown in your screenshot.
After copy & import the latest code I see:
It works, but it produce only the âbasicâ control (START, STOP, PAUSE).
Can you maybe share again your latest code?
Many thanks and best regards
Holger
Ups! Sorry Timothy and thanks to Holger!
Yes, I thought that there will come a better solution, which will no longer need
my quick and dirty Node-RED implementation. But as this not happend I did some improvements to my âcodeâ. I post the latest version below.
In my installation âWater level selectâ, âClean Speedâ and âDoNotDisturbEnabledâ are disabled, because they donât work with my device. But everything I need for my automations works well.
[{"id":"c36b1de29da98452","type":"tab","label":"Yeedi wraper","disabled":false,"info":"","env":[]},{"id":"00da3990aa1dcec5","type":"junction","z":"c36b1de29da98452","x":800,"y":140,"wires":[["525bb7f78609c84a","3c937b1ec2f0b8c7","bbb4a8505e9503b2","adaf2722574f64cc","8a9b9d352ef70daf"]]},{"id":"c726b10d2784cbb0","type":"junction","z":"c36b1de29da98452","x":880,"y":640,"wires":[["c38683f58d3997ad","81b5a564a295f628","311142287a52e12d"]]},{"id":"87a15596779f9eaf","type":"junction","z":"c36b1de29da98452","x":800,"y":660,"wires":[["20f68fece4a2323d"]]},{"id":"90410e3b60b0b397","type":"inject","z":"c36b1de29da98452","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":true,"onceDelay":"2","topic":"","payload":"true","payloadType":"bool","x":90,"y":420,"wires":[["2988643542f59213"]]},{"id":"bdf6cee0f07c166f","type":"ha-sensor","z":"c36b1de29da98452","name":"Battery","entityConfig":"3a94ee165e08d90c","version":0,"state":"payload.value","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1000,"y":440,"wires":[[]]},{"id":"e821d0d77d09b055","type":"ha-sensor","z":"c36b1de29da98452","name":"Cleaning time","entityConfig":"57eb93c83f69ac2e","version":0,"state":"payload.value.totalTimeFormatted","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1020,"y":560,"wires":[[]]},{"id":"c38683f58d3997ad","type":"ha-sensor","z":"c36b1de29da98452","name":"LifeSpanFilter","entityConfig":"7dd1cf189c1cfd51","version":0,"state":"payload.value.filter","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1020,"y":620,"wires":[[]]},{"id":"311142287a52e12d","type":"ha-sensor","z":"c36b1de29da98452","name":"LifeSpanSideBrush","entityConfig":"e9895259df570745","version":0,"state":"payload.value.side_brush","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1030,"y":680,"wires":[[]]},{"id":"81b5a564a295f628","type":"ha-sensor","z":"c36b1de29da98452","name":"LifeSpanMainBrush","entityConfig":"b0c84fca9e24b9a7","version":0,"state":"payload.value.main_brush","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1030,"y":740,"wires":[[]]},{"id":"9fe41e61c7754f63","type":"switch","z":"c36b1de29da98452","name":"Type","property":"payload.type","propertyType":"msg","rules":[{"t":"eq","v":"info","vt":"str"},{"t":"eq","v":"ChargeState","vt":"str"},{"t":"eq","v":"SleepStatus","vt":"str"},{"t":"eq","v":"BatteryInfo","vt":"str"},{"t":"eq","v":"DoNotDisturbEnabled","vt":"str"},{"t":"eq","v":"LastCleanLogs","vt":"str"},{"t":"eq","v":"LifeSpan","vt":"str"},{"t":"eq","v":"WaterBoxInfo","vt":"str"},{"t":"eq","v":"WaterLevel","vt":"str"},{"t":"eq","v":"LastError","vt":"str"},{"t":"eq","v":"MoppingSystemInfo","vt":"str"},{"t":"eq","v":"CleanSpeed","vt":"str"},{"t":"eq","v":"CurrentUsedSpotAreas","vt":"str"},{"t":"eq","v":"CleanSum","vt":"str"},{"t":"eq","v":"CurrentUsedCustomAreaValues","vt":"str"},{"t":"eq","v":"CleanReport","vt":"str"},{"t":"eq","v":"CleanLog","vt":"str"},{"t":"eq","v":"CurrentSpotAreaID","vt":"str"},{"t":"eq","v":"ChargingPosition","vt":"str"},{"t":"eq","v":"Position","vt":"str"},{"t":"eq","v":"RelocationState","vt":"str"},{"t":"eq","v":"ContinuousCleaningEnabled","vt":"str"},{"t":"eq","v":"CarpetPressure","vt":"str"},{"t":"eq","v":"DusterRemind","vt":"str"},{"t":"nempty"}],"checkall":"false","repair":false,"outputs":25,"x":650,"y":460,"wires":[["00da3990aa1dcec5"],["f327048b487ed5a1"],["5d1d20b36d21bce0"],["bdf6cee0f07c166f"],["d4982f217a65f53d"],["e821d0d77d09b055"],["c726b10d2784cbb0"],["f297f8a81f991db7"],["cd837e27c3c0e299","cea5572e7403d243"],["11f2903215eb3289"],["87a15596779f9eaf"],["2874e726920d1cf2","f21ed8154349a106"],["87a15596779f9eaf"],["87a15596779f9eaf"],["87a15596779f9eaf"],["87a15596779f9eaf"],["87a15596779f9eaf"],["87a15596779f9eaf"],["87a15596779f9eaf"],["87a15596779f9eaf"],["87a15596779f9eaf"],["87a15596779f9eaf"],["87a15596779f9eaf"],["87a15596779f9eaf"],["225ce8aa973c5ead"]]},{"id":"f327048b487ed5a1","type":"ha-sensor","z":"c36b1de29da98452","name":"ChargeState","entityConfig":"ad0c38ababa07eab","version":0,"state":"payload.value","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1010,"y":320,"wires":[[]]},{"id":"5d1d20b36d21bce0","type":"ha-sensor","z":"c36b1de29da98452","name":"SleepStatus","entityConfig":"68db47065a6ef493","version":0,"state":"payload.value","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1010,"y":380,"wires":[[]]},{"id":"3cb7a4187cef1384","type":"ha-button","z":"c36b1de29da98452","name":"Start","version":0,"debugenabled":false,"outputs":1,"entityConfig":"cd59296b3642fc5c","outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"}],"x":90,"y":180,"wires":[["51ff3991aea481b4"]]},{"id":"b1b628156c3d4028","type":"ha-button","z":"c36b1de29da98452","name":"Return","version":0,"debugenabled":false,"outputs":1,"entityConfig":"7325ec802bba397b","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":90,"y":300,"wires":[["20953eccddd58530"]]},{"id":"1bdadabc46d015c2","type":"ha-button","z":"c36b1de29da98452","name":"Pause","version":0,"debugenabled":false,"outputs":1,"entityConfig":"b533c3a699890cd4","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":90,"y":240,"wires":[["88e6a95b95efb7b1"]]},{"id":"f297f8a81f991db7","type":"ha-sensor","z":"c36b1de29da98452","name":"WaterBoxInfo","entityConfig":"e34cfd540f16d734","version":0,"state":"payload.value","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1020,"y":800,"wires":[[]]},{"id":"20f68fece4a2323d","type":"debug","z":"c36b1de29da98452","name":"May add this sensor","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":780,"y":780,"wires":[]},{"id":"b6d97942bb5bbaef","type":"inject","z":"c36b1de29da98452","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":90,"y":540,"wires":[["253c872ca05028d1"]]},{"id":"d4982f217a65f53d","type":"ha-sensor","z":"c36b1de29da98452","d":true,"name":"DoNotDisturbEnabled","entityConfig":"d35da5b318112ba6","version":0,"state":"payload.value","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1040,"y":500,"wires":[[]]},{"id":"23f81db4987b0488","type":"catch","z":"c36b1de29da98452","name":"","scope":null,"uncaught":false,"x":100,"y":780,"wires":[["74342f8d20f4d96c","279df857454cc16b"]]},{"id":"74342f8d20f4d96c","type":"debug","z":"c36b1de29da98452","name":"Error","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":250,"y":800,"wires":[]},{"id":"279df857454cc16b","type":"debug","z":"c36b1de29da98452","name":"ErrorCount","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"","statusType":"counter","x":270,"y":740,"wires":[]},{"id":"adaf2722574f64cc","type":"ha-sensor","z":"c36b1de29da98452","name":"infoVersion","entityConfig":"b96831e1d1553a23","version":0,"state":"payload.value.version","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1010,"y":80,"wires":[[]]},{"id":"bbb4a8505e9503b2","type":"ha-sensor","z":"c36b1de29da98452","name":"infoLibraryVersion","entityConfig":"e7a2778d65ea5020","version":0,"state":"payload.value.libraryVersion","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1030,"y":140,"wires":[[]]},{"id":"3c937b1ec2f0b8c7","type":"ha-sensor","z":"c36b1de29da98452","name":"infoDeviceClass","entityConfig":"85a9c5791d76aa0b","version":0,"state":"payload.value.deviceClass","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1020,"y":200,"wires":[[]]},{"id":"525bb7f78609c84a","type":"ha-sensor","z":"c36b1de29da98452","name":"infoDeviceModel","entityConfig":"c26aade3d531ab1d","version":0,"state":"payload.value.deviceModel","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1030,"y":260,"wires":[[]]},{"id":"8a9b9d352ef70daf","type":"ha-sensor","z":"c36b1de29da98452","name":"infoNickname","entityConfig":"ec7e92985f70e047","version":0,"state":"payload.value.nickname","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1020,"y":20,"wires":[[]]},{"id":"11f2903215eb3289","type":"ha-sensor","z":"c36b1de29da98452","name":"Last error","entityConfig":"641faaa33bf7c935","version":0,"state":"payload.value","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1000,"y":920,"wires":[[]]},{"id":"f2ba300fcc35a61e","type":"ha-button","z":"c36b1de29da98452","name":"Find","version":0,"debugenabled":false,"outputs":1,"entityConfig":"66e90eb44488f7c2","outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"}],"x":90,"y":120,"wires":[["fa52d38b0b9ffcfe"]]},{"id":"2874e726920d1cf2","type":"ha-sensor","z":"c36b1de29da98452","d":true,"name":"Clean Speed","entityConfig":"db14ba186a1d473e","version":0,"state":"payload.value","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1010,"y":980,"wires":[[]]},{"id":"225ce8aa973c5ead","type":"debug","z":"c36b1de29da98452","name":"missing selector","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":530,"y":780,"wires":[]},{"id":"cd837e27c3c0e299","type":"ha-sensor","z":"c36b1de29da98452","d":true,"name":"WaterLevel","entityConfig":"0b7df0473599124a","version":0,"state":"payload.value","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1210,"y":800,"wires":[[]]},{"id":"7fc253370fb0dad1","type":"ha-select","z":"c36b1de29da98452","d":true,"name":"Water level select","version":1,"debugenabled":false,"inputs":0,"outputs":1,"entityConfig":"ff80fda04a3a306f","mode":"listen","value":"payload","valueType":"msg","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"value"},{"property":"previousValue","propertyType":"msg","value":"","valueType":"previousValue"}],"x":120,"y":360,"wires":[["0251d2dce05830e3"]]},{"id":"2cc927c471112162","type":"api-call-service","z":"c36b1de29da98452","name":"Set waterlevel on startup","server":"5172b39f.89f00c","version":5,"debugenabled":false,"domain":"select","service":"select_option","areaId":[],"deviceId":[],"entityId":["select.water_level"],"data":"{\"option\":\"2\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1250,"y":860,"wires":[[]]},{"id":"cea5572e7403d243","type":"trigger","z":"c36b1de29da98452","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"0","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1020,"y":860,"wires":[["2cc927c471112162"]]},{"id":"1c454e77add1f6ae","type":"ha-switch","z":"c36b1de29da98452","d":true,"name":"","version":0,"debugenabled":false,"inputs":1,"outputs":2,"entityConfig":"a56a9f3fbc6d75f1","enableInput":true,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":90,"y":480,"wires":[["ad8c1eb364f0a740"],["c17ad6ea1cdfb571"]]},{"id":"0251d2dce05830e3","type":"change","z":"c36b1de29da98452","name":"","rules":[{"t":"set","p":"arg","pt":"msg","to":"$number(payload)","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"SetWaterLevel","tot":"str"},{"t":"delete","p":"previousValue","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":360,"wires":[["a09cc0d45524fc78"]]},{"id":"ed42c47797620926","type":"change","z":"c36b1de29da98452","name":"","rules":[{"t":"set","p":"arg","pt":"msg","to":"$number(payload)","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"SetCleanSpeed","tot":"str"},{"t":"delete","p":"previousValue","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":600,"wires":[["a09cc0d45524fc78"]]},{"id":"8c564e4bb2b9dc8f","type":"inject","z":"c36b1de29da98452","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"3","payloadType":"str","x":90,"y":660,"wires":[["ed42c47797620926"]]},{"id":"4c927895964adeb9","type":"ha-select","z":"c36b1de29da98452","d":true,"name":"Clean Speed","version":1,"debugenabled":false,"inputs":0,"outputs":1,"entityConfig":"8a95b99fa23f20f3","mode":"listen","value":"payload","valueType":"msg","outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"value"},{"property":"previousValue","propertyType":"msg","value":"","valueType":"previousValue"}],"x":110,"y":600,"wires":[["ed42c47797620926"]]},{"id":"5364624d1ac807f0","type":"api-call-service","z":"c36b1de29da98452","name":"Set clean speed on startup","server":"5172b39f.89f00c","version":5,"debugenabled":false,"domain":"select","service":"select_option","areaId":[],"deviceId":[],"entityId":["select.clean_speed"],"data":"{\"option\":\"2\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1260,"y":1060,"wires":[[]]},{"id":"f21ed8154349a106","type":"trigger","z":"c36b1de29da98452","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"0","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1020,"y":1060,"wires":[["5364624d1ac807f0"]]},{"id":"a09cc0d45524fc78","type":"ecovacs-deebot","z":"c36b1de29da98452","account":"103c02f73abdabfa","name":"Yeedi","deviceNumber":"1","connectOnStartup":true,"enableGetMapsOnStartup":false,"enableSimpleEvents":false,"x":650,"y":200,"wires":[["9fe41e61c7754f63"]]},{"id":"2988643542f59213","type":"ecovacs-deebot-command","z":"c36b1de29da98452","name":"","command":"Connect","arg":"","arg2":"","arg3":"","x":270,"y":420,"wires":[["a09cc0d45524fc78"]]},{"id":"51ff3991aea481b4","type":"ecovacs-deebot-command","z":"c36b1de29da98452","name":"","command":"Clean","arg":"","arg2":"","arg3":"","x":320,"y":180,"wires":[["a09cc0d45524fc78"]]},{"id":"20953eccddd58530","type":"ecovacs-deebot-command","z":"c36b1de29da98452","name":"","command":"Charge","arg":"","arg2":"","arg3":"","x":320,"y":300,"wires":[["a09cc0d45524fc78"]]},{"id":"88e6a95b95efb7b1","type":"ecovacs-deebot-command","z":"c36b1de29da98452","name":"","command":"Pause","arg":"","arg2":"","arg3":"","x":300,"y":240,"wires":[["a09cc0d45524fc78"]]},{"id":"c17ad6ea1cdfb571","type":"ecovacs-deebot-command","z":"c36b1de29da98452","d":true,"name":"","command":"DisableDoNotDisturb","arg":"","arg2":"","arg3":"","x":330,"y":500,"wires":[["a09cc0d45524fc78"]]},{"id":"ad8c1eb364f0a740","type":"ecovacs-deebot-command","z":"c36b1de29da98452","d":true,"name":"","command":"EnableDoNotDisturb","arg":"20:00","arg2":"6:00","arg3":"","x":330,"y":460,"wires":[["a09cc0d45524fc78"]]},{"id":"fa52d38b0b9ffcfe","type":"ecovacs-deebot-command","z":"c36b1de29da98452","name":"","command":"FindMe","arg":"30","arg2":"","arg3":"","x":270,"y":120,"wires":[["a09cc0d45524fc78"]]},{"id":"253c872ca05028d1","type":"ecovacs-deebot-command","z":"c36b1de29da98452","name":"","command":"EnableBorderSpin","arg":"","arg2":"","arg3":"","x":340,"y":540,"wires":[["a09cc0d45524fc78"]]},{"id":"147dd10bcc9c5309","type":"ha-button","z":"c36b1de29da98452","name":"Backwards","version":0,"debugenabled":false,"outputs":1,"entityConfig":"bfc18152a3137513","outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"}],"x":100,"y":60,"wires":[["d09f13bf1e75181b"]]},{"id":"d09f13bf1e75181b","type":"ecovacs-deebot-command","z":"c36b1de29da98452","name":"","command":"MoveBackward","arg":"","arg2":"","arg3":"","x":260,"y":60,"wires":[["a09cc0d45524fc78"]]},{"id":"3a94ee165e08d90c","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_battery","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"battery"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"entity_picture","value":""},{"property":"device_class","value":"battery"},{"property":"unit_of_measurement","value":"%"},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"57eb93c83f69ac2e","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_last_cleaning_time","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"last cleaning time"},{"property":"icon","value":"mdi:timer-outline"},{"property":"entity_category","value":"diagnostic"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"7dd1cf189c1cfd51","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_lifespan_filter","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"lifespan filter"},{"property":"icon","value":"mdi:wrench-outline"},{"property":"entity_category","value":"diagnostic"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":"%"},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"e9895259df570745","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_lifespann_sidebrush","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"lifespan sidebrush"},{"property":"icon","value":"mdi:wrench-outline"},{"property":"entity_category","value":"diagnostic"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":"%"},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"b0c84fca9e24b9a7","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_lifespann_mainbrush","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"lifespan mainbrush"},{"property":"icon","value":"mdi:wrench-outline"},{"property":"entity_category","value":"diagnostic"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":"%"},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"ad0c38ababa07eab","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_charge_state","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"charge state"},{"property":"icon","value":"mdi:power-plug"},{"property":"entity_category","value":""},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"68db47065a6ef493","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_sleep_state","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Sleep State"},{"property":"icon","value":"mdi:sleep"},{"property":"entity_category","value":""},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"cd59296b3642fc5c","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_start_automatic_cleaning","version":"6","entityType":"button","haConfig":[{"property":"name","value":"start automatic cleaning"},{"property":"icon","value":"mdi:play"},{"property":"entity_category","value":""},{"property":"entity_picture","value":""},{"property":"device_class","value":"update"}],"resend":false,"debugEnabled":false},{"id":"7325ec802bba397b","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_return_to_charging_station","version":"6","entityType":"button","haConfig":[{"property":"name","value":"return to charging station"},{"property":"icon","value":"mdi:rewind-outline"},{"property":"entity_category","value":""},{"property":"entity_picture","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"b533c3a699890cd4","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_pause_the_cleaning","version":"6","entityType":"button","haConfig":[{"property":"name","value":"pause cleaning"},{"property":"icon","value":"mdi:pause"},{"property":"entity_category","value":""},{"property":"entity_picture","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"e34cfd540f16d734","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_waterbox","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"waterbox"},{"property":"icon","value":"mdi:water-outline"},{"property":"entity_category","value":""},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"d35da5b318112ba6","type":"ha-entity-config","d":true,"server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_do_not_disturbe","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Do Not Disturb "},{"property":"icon","value":"mdi:cancel"},{"property":"entity_category","value":"config"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"b96831e1d1553a23","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_info_version","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"info version"},{"property":"icon","value":"mdi:information-outline"},{"property":"entity_category","value":"diagnostic"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"e7a2778d65ea5020","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_info_library_version","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"info library version"},{"property":"icon","value":"mdi:information-outline"},{"property":"entity_category","value":"diagnostic"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"85a9c5791d76aa0b","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_info_device_class","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"info device class"},{"property":"icon","value":"mdi:information-outline"},{"property":"entity_category","value":"diagnostic"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"c26aade3d531ab1d","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_info_device_model","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"info device model"},{"property":"icon","value":"mdi:information-outline"},{"property":"entity_category","value":"diagnostic"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"ec7e92985f70e047","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_info_nickname","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"info nickname"},{"property":"icon","value":"mdi:robot-vacuum"},{"property":"entity_category","value":"config"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"641faaa33bf7c935","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_last_error","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"last error"},{"property":"icon","value":"mdi:bug-outline"},{"property":"entity_category","value":"diagnostic"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"66e90eb44488f7c2","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"find me","version":"6","entityType":"button","haConfig":[{"property":"name","value":"Find me"},{"property":"icon","value":"mdi:home-search"},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"db14ba186a1d473e","type":"ha-entity-config","d":true,"server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_clean_speed","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Clean Speed"},{"property":"icon","value":"mdi:speedometer"},{"property":"entity_category","value":"config"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"0b7df0473599124a","type":"ha-entity-config","d":true,"server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_water_level","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Water Level"},{"property":"icon","value":"mdi:water-percent"},{"property":"entity_category","value":"config"},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""}],"resend":false,"debugEnabled":false},{"id":"ff80fda04a3a306f","type":"ha-entity-config","d":true,"server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_water_level_select","version":"6","entityType":"select","haConfig":[{"property":"name","value":"Water Level"},{"property":"icon","value":"mdi:water-percent"},{"property":"entity_category","value":"config"},{"property":"entity_picture","value":""},{"property":"options","value":["1","2","3","4"]}],"resend":false,"debugEnabled":false},{"id":"5172b39f.89f00c","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","areaSelector":"id","deviceSelector":"id","entitySelector":"id","statusSeparator":"-","statusYear":"2-digit","statusMonth":"2-digit","statusDay":"2-digit","statusHourCycle":"h23","statusTimeFormat":"h:m:s","enableGlobalContextStore":false},{"id":"a56a9f3fbc6d75f1","type":"ha-entity-config","d":true,"server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_do_not_disturbe_switch","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"Do Not Disturb"},{"property":"icon","value":"mdi:cancel"},{"property":"entity_category","value":"config"},{"property":"entity_picture","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"8a95b99fa23f20f3","type":"ha-entity-config","d":true,"server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi_clean_speed_select","version":"6","entityType":"select","haConfig":[{"property":"name","value":"Clean Speed"},{"property":"icon","value":"mdi:speedometer"},{"property":"entity_category","value":"config"},{"property":"entity_picture","value":""},{"property":"options","value":["1","2","3","4"]}],"resend":false,"debugEnabled":false},{"id":"103c02f73abdabfa","type":"ecovacs-account","countryCode":"AT","name":"","login":"yeedi.com"},{"id":"bfc18152a3137513","type":"ha-entity-config","server":"5172b39f.89f00c","deviceConfig":"7f325b3453da9f3f","name":"yeedi backwards","version":"6","entityType":"button","haConfig":[{"property":"name","value":"yeedi backwards"},{"property":"icon","value":"yeedi backwards"},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":false,"debugEnabled":false},{"id":"7f325b3453da9f3f","type":"ha-device-config","name":"yeedi vacuum cleaner","hwVersion":"","manufacturer":"Ecovac","model":"yeedi 2 hybrid","swVersion":"0.9"}]
What I get is:
red box that says Import unrecognized types:
ecovacs-deebot
ecovacs-account
then a blue box that says
Imported
1 flow
50 nodes
1 configuration node
Thank You ! I appreciate that - now the import works,
I thought that would get me a vacuum to add to my control on homeassistant - but I am looking thru the nodes now to see if I need to change something there for my instance.
I actually have 2 yeedi 1 upstairs and 1 down
So I will have to learn more about ecovacs and nodered.
