I currently running Home Assistant on a Raspberry Pi using HassOS. I’ve installed a ZST10 as my Z-Wave controller and the Z-Wave integration (not OpenZwave). I just have a few devices installed, a couple of window sensors a motion sensor, and a GD00Z-4 garage door opener. All are working except the GD00-4 which is seen as only a binary sensor and not a cover. It also doesn’t show if the Garage Door is open or closed. I’ve installed the GD00Z-4 as a secure node put a new battery in the tilt sensor and repaired the tilt sensor to the GD00Z-4. No affect. I seen no errors or even warnings in the ozw log.
In looking through the forums for a solution, I found problems with the GD00Z-4 going back to 2016 with a variety of recommended fixes. However, the fixes all seem to require a patch to older versions of HA.
So is there a fix or is this as good as I’m gong to get? Did I do something wrong or not complete a step?
Should I go to OpenZwave or will I still have the same problem? As a beta I’m not looking for more problems but if it fixes my problem, I’ll try it. I"m assuming I would need to first delete my existing Z-Wave integration; is there a recommended procedure for migration?
