Source of request : addons builds fail when building from multi-arch base images
Request1: allowing the “–platform” tag in the build.json file would allow to reference each relevant platform, which would then be passed to the Dockerfile through the “$BUILD_FROM” tag. I’ve added the relevant documentation at the bottom of the post
Issue2 : a REGEX is applied and does not allow the “–platform” characters in the build.json
Can't parse /data/addons/git/db21ed7f/addons_updater/build.json: does not match regular expression ^([a-zA-Z\-\.:\d{}]+/)*?([\-\w{}]+)/([\-\w{}]+)(:[\.\-\w{}]+)?$ for dictionary value @ data['build_from']['aarch64']. Got '--platform=linux/arm64 homeassistant/aarch64-base-python:3.9-alpine3.13'
- Request2 : would it be possible to allow the platform tag in the REGEX?
Thank you
“–platform” tag : The optional --platform
flag can be used to specify the platform of the image in case FROM
references a multi-platform image. For example, linux/amd64
, linux/arm64
, or windows/amd64
. By default, the target platform of the build request is used. Global build arguments can be used in the value of this flag, for example automatic platform ARGs allow you to force a stage to native build platform (--platform=$BUILDPLATFORM
), and use it to cross-compile to the target platform inside the stage. (Dockerfile reference | Docker Documentation)
