I have several of the GE 14287, and they are still reporting as 67% / high when I set speed to medium Running 2021.12.3, and I see the changes from the PR are integrated. I tried to re-interview the switch, but no improvement. Here’s a zwave-js device dump
Summary
"nodeId": 12,
"index": 0,
"installerIcon": 1024,
"userIcon": 1024,
"status": 4,
"ready": true,
"isListening": true,
"isRouting": true,
"isSecure": false,
"manufacturerId": 99,
"productId": 12593,
"productType": 18756,
"firmwareVersion": "5.24",
"zwavePlusVersion": 1,
"deviceConfig": {
"filename": "/data/db/devices/0x0063/14287.json",
"isEmbedded": true,
"manufacturer": "GE/Jasco",
"label": "14287 / ZW4002",
"description": "In-Wall Smart Fan Control",
"devices": [
"productId": 12593
"firmwareVersion": {
"min": "0.0",
"max": "255.255"
"associations": {},
"paramInformation": {
"_map": {}
"compat": {
"valueIdRegex": {},
"treatBasicSetAsEvent": true,
"removeCCs": {}
"metadata": {
"inclusion": "1. Follow the instructions for your Z-Wave certified controller to include a device to the Z-Wave network.\n2. Once the controller is ready to include your device, press and release the top or bottom of the smart fan control switch (rocker) to include it in the network.\n3. Once your controller has confirmed the device has been included, refresh the Z-Wave network to optimize performance",
"exclusion": "1. Follow the instructions for your Z-Wave certified controller to exclude a device from the Z-Wave network. \n2. Once the controller is ready to Exclude your device, press and release the top or bottom of the wireless smart switch (rocker) to exclude it from the network",
"reset": "1. Quickly press ON (Top) button three (3) times then immediately press the OFF (Bottom) button three (3) times. The LED will flash ON/OFF 5 times when completed successfully.\nNote: This should only be used in the event your network\u2019s primary controller is missing or otherwise inoperable",
"manual": "https://products.z-wavealliance.org/ProductManual/File?folder=&filename=MarketCertificationFiles/2506/Binder2.pdf"
"interviewAttempts": 1,
"endpoints": [
"nodeId": 12,
"index": 0,
"userIcon": 1024,
"deviceClass": {
"basic": {
"key": 4,
"label": "Routing Slave"
"generic": {
"key": 17,
"label": "Multilevel Switch"
"specific": {
"key": 8,
"label": "Fan Switch"
"mandatorySupportedCCs": [
32,
38,
133,
89,
114,
115,
134,
94
"mandatoryControlledCCs": []
"values": [
"endpoint": 0,
"commandClass": 32,
"commandClassName": "Basic",
"property": "currentValue",
"propertyName": "currentValue",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Current value",
"min": 0,
"max": 99
"value": 66
"endpoint": 0,
"commandClass": 32,
"property": "targetValue",
"propertyName": "targetValue",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"label": "Target value",
"min": 0,
"max": 99
"endpoint": 0,
"commandClass": 32,
"property": "event",
"propertyName": "event",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Event value",
"min": 0,
"max": 255
"endpoint": 0,
"commandClass": 38,
"commandClassName": "Multilevel Switch",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueChangeOptions": [
"transitionDuration"
"min": 0,
"max": 99
"value": 32
"endpoint": 0,
"commandClass": 38,
"property": "duration",
"propertyName": "duration",
"ccVersion": 1,
"metadata": {
"type": "duration",
"readable": true,
"writeable": true,
"label": "Transition duration"
"endpoint": 0,
"commandClass": 38,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"min": 0,
"max": 99
"value": 99
"endpoint": 0,
"commandClass": 38,
"property": "Up",
"propertyName": "Up",
"ccVersion": 1,
"metadata": {
"type": "boolean",
"readable": true,
"writeable": true,
"label": "Perform a level change (Up)",
"ccSpecific": {
"switchType": 2
"endpoint": 0,
"commandClass": 38,
"property": "Down",
"propertyName": "Down",
"ccVersion": 1,
"metadata": {
"type": "boolean",
"readable": true,
"writeable": true,
"label": "Perform a level change (Down)",
"ccSpecific": {
"switchType": 2
"endpoint": 0,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"property": "manufacturerId",
"propertyName": "manufacturerId",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"min": 0,
"max": 65535
"value": 99
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"min": 0,
"max": 65535
"value": 18756
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"min": 0,
"max": 65535
"value": 12593
"endpoint": 0,
"commandClass": 134,
"commandClassName": "Version",
"property": "libraryType",
"propertyName": "libraryType",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Library type",
"states": {
"0": "Unknown",
"1": "Static Controller",
"2": "Controller",
"3": "Enhanced Slave",
"4": "Slave",
"5": "Installer",
"6": "Routing Slave",
"7": "Bridge Controller",
"8": "Device under Test",
"9": "N/A",
"10": "AV Remote",
"11": "AV Device"
"value": 3
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"ccVersion": 2,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version"
"value": "4.54"
"endpoint": 0,
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"ccVersion": 2,
"metadata": {
"type": "string[]",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions"
"value": [
"5.24"
"endpoint": 0,
"property": "hardwareVersion",
"propertyName": "hardwareVersion",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Z-Wave chip hardware version"
"value": 255
"endpoint": 0,
"commandClass": 112,
"commandClassName": "Configuration",
"property": 4,
"propertyName": "Invert Switch",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"description": "Invert the ON/OFF Switch State",
"label": "Invert Switch",
"default": 0,
"min": 0,
"max": 1,
"states": {
"0": "Default",
"1": "Invert"
"valueSize": 1,
"format": 1,
"allowManualEntry": false,
"isFromConfig": true
"value": 0
"endpoint": 0,
"commandClass": 43,
"commandClassName": "Scene Activation",
"property": "sceneId",
"propertyName": "sceneId",
"ccVersion": 0,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"label": "Scene ID",
"min": 1,
"max": 255
"endpoint": 0,
"commandClass": 43,
"property": "dimmingDuration",
"propertyName": "dimmingDuration",
"ccVersion": 0,
"metadata": {
"type": "any",
"readable": true,
"writeable": true,
"label": "Dimming duration"
"isFrequentListening": false,
"maxDataRate": 100000,
"supportedDataRates": [
40000,
100000
"protocolVersion": 3,
"supportsBeaming": true,
"supportsSecurity": false,
"nodeType": 1,
"zwavePlusNodeType": 0,
"zwavePlusRoleType": 5,
"deviceClass": {
"basic": {
"key": 4,
"generic": {
"key": 17,
"specific": {
"key": 8,
32,
38,
133,
89,
114,
115,
134,
94
"commandClasses": [
"id": 32,
"name": "Basic",
"version": 1,
"isSecure": false
"id": 38,
"name": "Multilevel Switch",
"version": 1,
"isSecure": false
"id": 133,
"name": "Association",
"version": 2,
"isSecure": false
"id": 89,
"name": "Association Group Information",
"version": 1,
"isSecure": false
"id": 114,
"name": "Manufacturer Specific",
"version": 2,
"isSecure": false
"id": 115,
"name": "Powerlevel",
"version": 1,
"isSecure": false
"id": 134,
"name": "Version",
"version": 2,
"isSecure": false
"id": 94,
"name": "Z-Wave Plus Info",
"version": 2,
"isSecure": false
"id": 90,
"name": "Device Reset Locally",
"version": 1,
"isSecure": false
"id": 112,
"name": "Configuration",
"version": 1,
"isSecure": false
"id": 86,
"name": "CRC-16 Encapsulation",
"version": 1,
"isSecure": false
"id": 44,
"name": "Scene Actuator Configuration",
"version": 1,
"isSecure": false
"id": 43,
"name": "Scene Activation",
"version": 1,
"isSecure": false
"id": 122,
"name": "Firmware Update Meta Data",
"version": 2,
"isSecure": false
"interviewStage": "Complete",
"deviceDatabaseUrl": "https://devices.zwave-js.io/?jumpTo=0x0063:0x4944:0x3131:5.24",
"statistics": {
"commandsTX": 104,
"commandsRX": 67,
"commandsDroppedRX": 0,
"commandsDroppedTX": 0,
"timeoutResponse": 0
"highestSecurityClass": -1
