At the moment (April 2024) the following setup works without any add-ons:
- You will need Pulse Audio client binaries (
pacat,paplay,pactl). They used to be present in the main HA container, but were removed. However, all libraries required by those binaries are still present in the main container - Take those binaries from the
hassio_audiocontainer and copy them to/mediaas follows:
docker cp hassio_audio:/usr/bin/pacat /media/
docker cp hassio_audio:/usr/bin/paplay /media/
docker cp hassio_audio:/usr/bin/pactl /media/
These commands can be run either from the host OS (if you have access to it, e.g. you are running HA supervised) or from the Advanced Terminal add-on. While doing this, you can verify whether HA would send the sound to the sound card you are expecting: run pactl info and verify whether “Default sink” is showing what you are expecting. If you have access to the host OS, the command would be: docker exec -it hassio_audio /usr/bin/pactl info.
- Now you can define something like this:
shell_command:
play_sound_file: "/media/paplay /media/myfile.ogg"
and use this as a service in automations. One downside: PulseAudio libraries in HA do not support MP3 files. WAV, OGG, FLAC is ok, but not MP3.
I’ve opened a feature request for a proper implementation of the local playback. Consider voting for it: click
