Requirements from manifest.json is not auto-installed
I’m working on a new component, but for some reason the requirements from manifest.json is not loaded.
Isn’t it supposed to load these requirements automatically on first run with the component in place?
manifest.json
“domain”: “landroid_cloud”,
“name”: “Worx Landroid Cloud”,
“documentation”: “https://www.home-assistant.io/components/landroid_cloud”,
“requirements”: [
“pyworxcloud==1.0.1”
“dependencies”: ,
“codeowners”: [“@MTrab”]
Error:
2019-05-29 13:41:24 ERROR (MainThread) [homeassistant.setup] Error during setup of component landroid_cloud
File “/home/landroidcloud/home-assistant/homeassistant/setup.py”, line 148, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/home/landroidcloud/home-assistant/homeassistant/components/landroid_cloud/init.py”, line 64, in setup
import pyworxcloud
ImportError: No module named ‘pyworxcloud’
Searching is your friend. As usual, the computer is correct.
Version 1.0.1 is no longer on PyPi.
Sorry - absolutely missed that.
Working now :slight_smile:
