Reset Bluetooth integration via Node-Red
I have an Airthings radon sensor that is connected to my HA via Bluetooth.
It works well for the most part, but becomes unavailable once or twice a day.
If I reset/reload the Bluetooth integration, it starts working again just fine.
Is there a way I can reload the Bluetooth via Node-Red?
Thank You,
Joshua
In a call service use the home assistant domain and reload config entry. Click the little load example bottom right corner to load an example of the data.
Thank you, I was looking for the wrong domain.
Where can I find the entry_id for me Bluetooth config?
Also, in case anyone else comes across this post. The root issue is that my tp-link UB500 adapter is listed as not supported here: Bluetooth - Home Assistant
So the proper solution wold be to get a different adapter, but I am using what I have on-hand.
If you go to integrations and go to the device page for the bluetooth adapter, the last set of numbers/letters of the ip address should be the entry id.
