I have had my Bond Bridge setup and working for some time with Home Assistant, but recently, through a sequence of events, the local API token was reset on my Bond Bridge. I cannot see any way to update it in the HA Bond Integration. Is there somewhere I can update the token? Or do I need to re-install the integration?
In the end I bit the bullet and removed and re-added the Bond bridge. I was mostly worried about how existing Node RED flows would react to entities being removed and re-added. Where the blinds were the same name, it looks like NR just used the name as it’s reference, so some of them worked without change. But I had changed some of the names in Bond slightly, but it was simple enough in the end to adjust the calls in NR.
It would be nice to have the option to update the access token, if it’s not available already.
