GigiDuru
(Gigi Duru)
April 24, 2023, 10:21am
1
Hi, I have the next automation to increase lamp brightness but I need to modify it, when reaches 100% to start from 0% and again 10%, 20%…
All this with a single button press because I’m using long click for something else.
alias: Lamp
description: ""
- platform: event
event_type: shelly.click
event_data:
device_id: 08f10a1fb131e8dc0aadf8dcef2ab7b6
device: shellyswitch25-483FDA8212BE
channel: 2
click_type: single
generation: 1
condition: []
- if:
- condition: trigger
then:
- device_id: 8bf218864e36b293e79f31d2c1eb7c41
domain: light
entity_id: light.livingroom_lamp
type: brightness_increase
enabled: true
mode: single
jchh
((not John))
April 24, 2023, 1:18pm
2
Try something like this:
- choose:
- conditions:
- condition: template
value_template "{{ state_attr('light.livingroom_lamp','brightness' < 256 }}"
sequence:
domain: light
- conditions:
value_template "{{ state_attr('light.livingroom_lamp','brightness' = 256 }}"
sequence:
domain: light
type: #3 command to set brightness to 0
I haven’t checked that I have the value_template correct, but hopefully it is enough for you to test. Note I a don’t know the command to set brightness to 0 so it is hashed out.
GigiDuru
(Gigi Duru)
April 24, 2023, 9:04pm
3
Thanks for your idea, I ended up with following automation, it’s not the shortest but it works:
alias: Lamp
description: ""
- platform: event
event_data:
channel: 2
click_type: single
generation: 1
condition: []
- choose:
- conditions:
value_template: "{{ states.light.livingroom_lamp.attributes.brightness < 254}}"
sequence:
domain: light
- conditions:
value_template: "{{ states.light.livingroom_lamp.attributes.brightness > 254}}"
sequence:
- service: light.turn_on
brightness: 0
- conditions:
- condition: device
type: is_off
domain: light
sequence:
domain: light
mode: single
