I would reset the energy counter of my devices :
I have 2 devices:
As you can see, the “energy” counter is not null, do you have a tip to reset it please ?
Thanks !
I have 2 devices:
Thanks !
I rested it with mathematical operation, but if you have a better solution, i’m interrested
I too am looking for a way to reset the accumulated kwh reading on a Zigbee device. Other than removing the device and adding it again.
also interested how to do this, for an zwave energy plug
seems not much follow up discussion on this thread.
I also have similar needs. I have 4 Eve Energy meters , added on different dates. I would like to see how I can reset all kWh accumalated readings say from 1st day of next month so that I can compare apple to apple for all 4 energy meters.
I guess there is one crude way… remove them all and add them back at the same time?
Hi @fuzzygel,
It’s easy to do that with Grafana for example.
Your data will do:
HomeAssistant → InfluxDB → Grafana
And in Grafana you can do this:
The tips is to do difference on the calculation
thank you so much, I am not familiar with InfluxDB or Grafana, Let me explore and I might (most likely ) need to come back with more questions
thanks in advance
