With the November update Efergy integration changed to UI based. With that, somehow I had wrong readings and I had to change some things. Readings seems to be working good now.
The problem is that until I fixed it I got bad readings (as yo can see in picture).
Is there a way to reset energy values? I know there is a reset service for reseting the utility meters and I did that, but the values are already saved in the energy feature
Hi Javier,
What query did you use? I have deleted and or updated entries from statistics, states and statistics_short_term, but the issue always returns
It happened to me too, the next day the corrupted statistics showed up again.
If I remember correctly, I fixed it by editing the sql the next month of the corrupted month data.
