Hi, I’ve gotten a power monitor setup using CircuitSetup Expandable 6 Channel ESP32 Energy Meter and esp32s nodemcu (aliexpress link). About every 12hrs I see that the ESP32 has reset and the reset reason is “RTC Watch Dog Reset Digital Core And RTC Module”. It is also happening at around 4am and 4pm every day. Below is my configuration and I have searched online on various sites for any similar cases but couldn’t find any. The version of ESPHome I’m using is 2023.2.4.
esp32s-energy-meter-1.yaml
esphome:
platform: ESP32
board: nodemcu-32s
on_boot:
priority: 300 #After sensors are up but before WIFI is connected
then:
- logger.log:
format: "on_boot started"
level: INFO
tag: energy-meter-1
# - delay: 1s
# - if:
# condition:
# - time.has_time:
# then:
# - logger.log:
# format: "on_boot Time has been set and is valid!"
# level: INFO
# tag: energy-meter-1
# - globals.set:
# id: boot_time
# value: !lambda |-
# return
# - lambda: |-
# id(bootTime).publish_state(id(sntpTime).now().strftime("on_boot %Y-%m-%d %I:%M:%S %p %z"));
# - globals.set:
# id: previous_total_mains_forward_active_power
# value: '0.0f'
# - globals.set:
# id: current_total_mains_forward_active_power
# value: '355533000.0f'
# - globals.set:
# value: !lambda 'return id(current_total_mains_forward_active_power);'
# - lambda: |-
# ESP_LOGI("energy-meter-1", "on_boot previous_total_mains_forward_active_power %s", id(previous_total_mains_forward_active_power));
# ESP_LOGI("energy-meter-1", "on_boot current_total_mains_forward_active_power %s", id(current_total_mains_forward_active_power));
- globals.set:
value: 'true'
- logger.log:
format: "on_boot finished"
level: INFO
tag: energy-meter-1
# Enable logging
logger:
# baud_rate: 19200
logs:
sensor: INFO
text_sensor: INFO
# Enable Home Assistant API
api:
reboot_timeout: 0s
services:
- service: set_previous_total_mains_forward_active_power
variables:
value: float
then:
- globals.set:
value: !lambda 'return value;'
ota:
password: <ommitted>
wifi:
ssid: <ommitted>
# ssid: <ommitted>
# password: <ommitted>
fast_connect: true
ap:
ssid: <ommitted>
captive_portal:
web_server:
port: 80
debug:
update_interval: 30s
time:
- platform: sntp
timezone: <ommitted>
# timezone: <ommitted>
on_time_sync:
then:
- logger.log:
format: "on_time_sync Synchronized system clock"
level: INFO
tag: energy-meter-1
- lambda: |-
if (!id(time_synced)) {
id(bootTime).publish_state(id(sntpTime).now().strftime("on_time_sync %Y-%m-%d %I:%M:%S %p %z"));
id(hardwareStatus).turn_on().perform();
- globals.set:
value: 'true'
globals:
- id: boot_completed
type: bool
restore_value: false
initial_value: 'false'
- id: time_synced
type: bool
- id: total_mains_forward_active_energy_updated
type: bool
- id: previous_total_mains_forward_active_power
type: float
initial_value: '0.0f'
- id: current_total_mains_forward_active_power
type: float
restore_value: true
initial_value: '1.0f'
# - id: boot_time
# type: std::string
# restore_value: no
# initial_value: '"undefined yyyy-MM-dd HH:mm:ss"'
spi:
clk_pin: 18
miso_pin: 19
mosi_pin: 23
#substitutions:
# Change the disp_name to something you want
# disp_name: energy-meter-1
# Current Transformers:
# 20A/25mA SCT-006: 11143
# 30A/1V SCT-013-030: 8650
# 50A/1V SCT-013-050: 15420
# 80A/26.6mA SCT-010: 41660
# 100A/50ma SCT-013-000: 27518
# 120A/40mA: SCT-016: 41787
# 200A/100mA SCT-024: 27518
#current_cal: '30853'
# Jameco 9VAC Transformer:
# For meter versions:
# >= v1.3: 7305
#voltage_cal: '11847'
light:
- platform: status_led
pin: GPIO2
restore_mode: ALWAYS_OFF
text_sensor:
- platform: debug
reset_reason:
- platform: version
- platform: debug
free:
- platform: wifi_signal
update_interval: 60s
name: Total Mains Forward Active Power
lambda: |-
ESP_LOGI("energy-meter-1", "totalMainsForwardActivePower running");
if (!id(total_mains_forward_active_energy_updated)) {
ESP_LOGI("energy-meter-1", "totalMainsForwardActivePower global variables not updated");
"totalMainsForwardActivePower initial previous_total_mains_forward_active_power %f",
"totalMainsForwardActivePower initial current_total_mains_forward_active_power %f",
ESP_LOGI("energy-meter-1", "totalMainsForwardActivePower updating");
if (id(current_total_mains_forward_active_power) == id(current_total_mains_forward_active_power)) {
id(previous_total_mains_forward_active_power) = id(current_total_mains_forward_active_power);
} else {
ESP_LOGW("energy-meter-1",
"totalMainsForwardActivePower current_total_mains_forward_active_power is not set!");
id(previous_total_mains_forward_active_power) = 0.0f;
id(total_mains_forward_active_energy_updated) = true;
ESP_LOGD("energy-meter-1", "l0ct4fWh state %f", id(l0ct4fWh).state);
ESP_LOGD("energy-meter-1", "l1ct1fWh state %f", id(l1ct1fWh).state);
ESP_LOGD("energy-meter-1", "l2ct1fWh state %f", id(l2ct1fWh).state);
ESP_LOGD("energy-meter-1", "previous_total_mains_forward_active_power %f", id(previous_total_mains_forward_active_power));
if (id(l0ct4fWh).state == id(l0ct4fWh).state &&
id(l1ct1fWh).state == id(l1ct1fWh).state &&
id(l2ct1fWh).state == id(l2ct1fWh).state) {
id(l0ct4fWh).state + id(l1ct1fWh).state +
id(l2ct1fWh).state + id(previous_total_mains_forward_active_power);
ESP_LOGI("energy-meter-1", "totalMainsForwardActivePower current_total_mains_forward_active_power %f", id(current_total_mains_forward_active_power));
return -1.0f;
accuracy_decimals: 2
unit_of_measurement: Wh
icon: "mdi:flash-circle"
device_class: energy
state_class: total
update_interval: 5s
- platform: atm90e32
# layer 0 - UPS - CT1-3
line_frequency: 50Hz
cs_pin: 5
current_phases: 3
update_interval: 5s
gain_pga: 1X
frequency:
name: UPS Main Freq
phase_a:
voltage:
name: UPS Main Volts
accuracy_decimals: 1
current:
name: UPS Main Amps (l0ct1)
power:
name: UPS Main Watts (l0ct1)
reactive_power:
name: UPS Main VARs
power_factor:
name: UPS Main PF
forward_active_energy:
name: UPS Main Forward Wh
reverse_active_energy:
name: UPS Main Reverse Wh
gain_voltage: 11157
gain_ct: 27932
# layer 0 - Mains 3 - CT4-6
cs_pin: 4
current_phases: 3
update_interval: 5s
gain_pga: 1X
frequency:
name: Mains 3 Freq
phase_a:
voltage:
name: Mains 3 Volts
current:
name: Mains 3 Amps (l0ct4)
power:
name: Mains 3 Watts (l0ct4)
reactive_power:
name: Mains 3 VARs
power_factor:
name: Mains 3 PF
name: Mains 3 Forward Wh
name: Mains 3 Reverse Wh
gain_voltage: 14545
gain_ct: 27562
phase_b:
current:
power:
gain_voltage: 14545
gain_ct: 27562
phase_c:
current:
power:
gain_voltage: 14545
gain_ct: 27562
# layer 1 - Mains 1 - CT1-3
cs_pin: 0
current_phases: 3
update_interval: 5s
gain_pga: 1X
frequency:
name: Mains 1 Freq
phase_a:
voltage:
name: Mains 1 Volts
current:
name: Mains 1 Amps (l1ct1)
power:
name: Mains 1 Watts (l1ct1)
reactive_power:
name: Mains 1 VARs
power_factor:
name: Mains 1 PF
name: Mains 1 Forward Wh
name: Mains 1 Reverse Wh
gain_voltage: 14508
gain_ct: 28130
phase_b:
current:
power:
gain_voltage: 14508
gain_ct: 27562
phase_c:
current:
power:
gain_voltage: 14508
gain_ct: 26373
# layer 1 - Mains 1 - CT4-6
cs_pin: 16
current_phases: 3
update_interval: 5s
gain_pga: 1X
phase_a:
current:
power:
gain_voltage: 14508
gain_ct: 27562
phase_b:
current:
power:
gain_voltage: 14508
gain_ct: 27740
phase_c:
current:
power:
gain_voltage: 14508
gain_ct: 26373
# layer 2 - Mains 2 - CT1-3
cs_pin: 27
current_phases: 3
update_interval: 5s
gain_pga: 1X
frequency:
name: Mains 2 Freq
phase_a:
voltage:
name: Mains 2 Volts
current:
name: Mains 2 Amps (l2ct1)
power:
name: Mains 2 Watts (l2ct1)
reactive_power:
name: Mains 2 VARs
power_factor:
name: Mains 2 PF
name: Mains 2 Forward Wh
name: Mains 2 Reverse Wh
gain_voltage: 14582
gain_ct: 27562
phase_b:
current:
power:
gain_voltage: 14582
gain_ct: 27562
phase_c:
current:
power:
gain_voltage: 14582
gain_ct: 27562
button:
- platform: restart
- platform: safe_mode
