I bought a SkyConnect and originally wanted to use it for thread only, so I went through the advised process for making it thread-only, but met with failure to connect any thread devices for reasons unknown (probably my own incompetence). I took it offline but now would like to use it in default mode as if I had not tried using it before. I have removed the Thread and the OT integrations. Is there anything else I need to do before being able to make a fresh start? Is there a way to reset the dongle?
You have to flash Zigbee only firmware. Then you can use it with ZHA or Zigbee2MQTT
Use this link in Chrome or Edge
Thank you!
