So, what I want to do, is to reset the time in a “DELAY” node. Right now, when I toggle, a Sonoff ON, the NodeRed sequence that has a 20 minute delay, turns OFF, 20 minutes later.
The following is the code for the above sequence.
[{"id":"7feb05f2.e27b3c","type":"server-state-changed","z":"c43dc3f2.667b","name":"Toggle Sonoff T1","server":"66f9160a.09b8e8","entityidfilter":"switch.sonoff_switch_t1","entityidfiltertype":"substring","haltifstate":"","x":160,"y":80,"wires":[["65129506.c20bbc"]]},{"id":"679a54b1.3783fc","type":"api-call-service","z":"c43dc3f2.667b","name":"Turn Off Sonoff T1","server":"66f9160a.09b8e8","service_domain":"switch","service":"turn_off","data":"{\"entity_id\":\"switch.sonoff_switch_t1\"}","mergecontext":"","x":690,"y":80,"wires":[[]]},{"id":"65129506.c20bbc","type":"switch","z":"c43dc3f2.667b","name":"switch","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":330,"y":80,"wires":[["421e8a8c.a45ca4"],[]]},{"id":"421e8a8c.a45ca4","type":"delay","z":"c43dc3f2.667b","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"hours","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":480,"y":80,"wires":[["679a54b1.3783fc"]]},{"id":"66f9160a.09b8e8","type":"server","z":"","name":"Home Assistant","url":"https://MyDomain.duckdns.org:8123","pass":"xyz123abc456"}]
With the 20 minute delay, if I toggle the Sonoff ON, and about 15 minutes later, I were to toggle the Sonoff OFF then back ON. 5 minutes later the Sonoff would turn OFF. What I would like, is when I Toggle the Sonoff, OFF then ON, 15 minutes later, the timer to reset back to “0”. So the Sonoff take another 20 minutes before it turns OFF.
Can someone show me what I need to add, that will cause the “Delay” node to restart the it’s timer.
