Hello everybody,
I’d like to count the number of times, when the motion sensor sees me, but decides to not switch on the light, just because it’s already bright enough in the room.
So, I’ve created a counter, using the helper entites and basically it works nicely. Each time the sensor sees me during the day, the number is incremented by 1.
But then I wanted to reset this counter each night at 03:00h. I’ve done something similar in the past and so I’ve chosen the utility meter to reset my counter … and this does not work. My first counter has been created directly in the configuration.yaml and this works. The new one has been created using the UI … and resetting does not work. Of course I could create an automation and reset the counter this way, but on one hand, I don’t want to have my lists of automations spammed by too many ‘tidy up scripts’ and secondly I would like to understand, why it worked for the first counter and not for the second one.
configuration.yaml:
#counters
counter:
my_custom_counter:
initial: 1
step: 1
utility_meter:
counter_meter:
source: counter.my_custom_counter
cycle: daily
room1_too_bright:
#created with UI
source: counter.room1TooBright
cycle: daily
offset: "03:00:00"
So my expectation was that this utility_meter, although it has been designed to do something different, would reset my simple counter, but it doesn’t.
I would be nice if someone could tell me what I did wrong.
Thanks,
Fridolin
