Resetting counters on Aeotech Switch 6
Hi there,
I have sucessfully set up a central HA supervised machine in the basement, being fed by a Raspberry using Zwave2MQTT. I’ve paired a (used) Aeotech Switch 6 with this one and everything is working flawlessly.
The only thing bugging me is the fact that this switches kWh counter is not starting at 0, even after having reset that thing several times. My question therefore is now: how can I reset that meter?
Tried using the trick mentioned at #SOLVED# Switching from HA builtin to Zwave2Mqtt reset accumulated power meter value but it didn’t help either. Regarding the devices config guide (https://aeotec.freshdesk.com/helpdesk/attachments/6102433596), the mentioned topics should be the same for the switch.
Please help!
If I recall (I have since moved away from this device & ZWAVE in general ) the topics to do the reset are between 30-33 you can check the zwave2mqtt gui for the device and check the parameters that show up. You are looking for something like “Reset”
