I’m trying to get HA to show me how much energy is left in my batteries which are connected to my solar panels. I therefore created two helpers. One is tracking the energy flow TO the battery and the other one the flow OUT of the battery. I then created a template sensor that subtracts the second value from the first one. I also multiply the first value by 0,917, because that is roughly the overall efficiency from the panels to the grid.
As all of this isn’t perfectly accurate, I want to reset the value from time to time and I thought the time when the battery is “empty” is pefect for that. So a new cycle should start, whenever the battery reaches the lower voltage threshold and the micro-inverter stops drawing energy from the battery. I wrote an automation for that purpose, but it doesn’t work at all. The counters are not resetting.
The template sensor for the calculation looks like this:
template:
- sensor:
- name: "Energie im Akku"
unique_id: "energie_im_akku"
unit_of_measurement: "kWh"
state_class: "total"
state: >
{{ states('sensor.akku_einspeisung')|float(0) | multiply(0.917) - states('sensor.akkuentnahme')|float(0) }}
And this is the automation:
alias: Akkuladezustand Reset
description: ""
- platform: numeric_state
entity_id:
- sensor.shelly_plus_plug_s_switch_0_power
for:
hours: 0
minutes: 30
seconds: 0
below: 2
condition: []
- service: utility_meter.reset
entity_id:
- sensor.akku_einspeisung
- sensor.akkuentnahme
metadata: {}
data: {}
mode: single
Any idea what i need to change?
