I need te reset or re-install the Companion app for Android. Following the steps like described at the website does not seems to work at all. This are the steps:
"At times you may need to start fresh with the Android app as a new feature may not be working properly or something odd happens.
- Check that Home Assistant Core and the Android app are up to date.
- Clear Storage or App data in Android app.
- In Home Assistant navigate to Configuration > Integration. Remove the mobile app entry for the device in question.
- Restart Home Assistant.
- Log back into Android app. If you have more than 1 device make sure to rename the device under App Configuration.
- Restart Home Assistant once more to register the
notify.mobile_app
service call."
After doing this I don’t get any first welcome screen, like here: https://companion.home-assistant.io/docs/getting_started/getting-started
Instead I only get the possibility to fill in the https://example.duckdns.org:8123 url. This is a problem, cause at this moment I can’t access my HA at all from an external address. (I can connect just fine by 192.x.x.x at my home-network).
Is the first login-screen maybe changed or maybe I’m just overlooking something small, but every help is appriciated
