Resideo sensor
Not sure when this started happening. I have a t10 Thermostat. It has multiplesensors in the house. They sense temp, humidity, motion. Everything worked great then home assitant stopped sensing motion. Tried resetting everything. It still wont sense motion. Does anyone have any idea what I can do?
Do you use the Resideo app too? Do they show motion in the app? What integration are you using in HA?
Resideo app doesnt show motion. Homekit integration.
I dont use motion in the app but it is enabled.
If the app isn’t detecting motion as well then it is a problem between the sensor and the thermostat. Reset one of the sensors and then pair it again with the thermostat and see if this fixes it.
tried that no dice
