Resize floorplan with custom:floorplan-card card
Hi
I am trying to create a floorplan in HA from a svg using the custom:floorplan-card card. The size of the floorplan is quite small. Is there any way to customize the size of the svg displayed? The typical height and weight fields are not working
New panel, full size :thinking:
2 cards or more:
Select - Sidebar
or , add
aspect_ratio: 20%
image: /local/parter.png
aspect_ratio: 20%
yeah, but i want 2 cards, thats the problem :frowning: one for the ground floor and another for first floor
Have you tried Vertical_layout ?, other-vice resizing the picture in an editor to the size(or above) , might be the best option, works well with masonry_layout( i.e 2 or 3 beside each other, or “stacked above” each-other )
this is 2 pics, each 1660x1920, in horizontal-view, screensize on laptop is 1366x768 ( on my phone they are reduced to single(above eachother), so the “responsive” code work very well in HA, fix your picture would absolute be your best option
or, as [krskrab] suggested “Panel-view”, and then “inside the Floorplan” view, click Edit (on the right) and " + " to the left ( Add view ) then you get a “link” above (top menu) to those additional Panle-views you’d like
