I just tried this
binary_sensor:
- platform: ping
host: 192.168.xxx.xxx
count: 2
scan_interval: 180
sensors:
presence_cedric:
device_class: presence
value_template: "{{ is_state('binary_sensor.cedric','on') }}"
delay_off: 3600
The check configuration will takes forever with below error found in log:
Logger: aiohttp.server
Source: helpers/config_validation.py:748
First occurred: 8:27:47 PM (1 occurrences)
Last logged: 8:27:47 PM
Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/core.py", line 29, in post
errors = await async_check_ha_config_file(request.app["hass"])
File "/usr/src/homeassistant/homeassistant/config.py", line 874, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 215, in async_check_ha_config_file
p_validated = platform_schema(p_validated)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
cval = cvalue(key_path, value)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 495, in verify
return cast(Dict, schema(value))
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 215, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 339, in _exec
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 748, in validator
if key in config:
TypeError: argument of type 'int' is not iterable
