[resolved] Detected integration that called async_setup_platforms instead of awaiting async_forward_entry_setups; this will fail in version 2023.3
Nest Protect (battery) Integration including fixing the retrieving issue_token and cookies. This was forked and updated with the cookie auth method. Will I lose the entire integration when updating to 2023.3.x? The report issues link redirects to the original integration, I find that a bit puzzling.
Thanks in advance for helping or directing me in the wright heading.
Logger: homeassistant.helpers.frame
Source: helpers/frame.py:77
First occurred: 14:20:06 (1 occurrences)
Last logged: 14:20:06
Detected integration that called async_setup_platforms instead of awaiting async_forward_entry_setups; this will fail in version 2023.3. Please report issue to the custom integration author for nest_protect using this method at custom_components/nest_protect/init.py, line 126: hass.config_entries.async_setup_platforms(entry, PLATFORMS)
I also posted this in the discord channel for integrations.
Updated my HA to 2023.3.1 due to - see quote - but the Nest Protect integration with cookies methode remains uneffected. Will report back if anything changes. Cheers
Disclosure: Supervisor security vulnerability
Affected version
The security issue affected installation types Home Assistant OS and Home Assistant Supervised. This includes installations running on the Home Assistant Blue and Home Assistant Yellow.
The two other installation types, Home Assistant Container (Docker) and Home Assistant Core (own Python environment), have not been affected.
