Since updating all of my HA to Home Assistant 2023.6.2 Supervisor 2023.06.2 Operating System 10.3 Frontend 20230608.0 - latest | Studio Code Server (5.6.2), Home Assistant Google Drive Backup (0.110.4), InfluxDB (4.7.0), Grafana (8.3.0), Terminal & SSH (9.7.1), File editor (5.6.0), Samba share (10.0.2)
#1 P1 meter stopped calculating and #2 P1 meter started calculating. Inserted them both in Energy Dashboard just for showing the difference.
I also have an error message for the units m3 or m3/h.
![Screenshot 2023-06-20 at 12.54.47](https://community-assets.home-assistant.io/original/4X/5/f/c/5fc73aad726c22d70e9632c32fb6ffc0e2fe3aca.png)
What can I do to correct these errors?
I’ve received a log entry:
Logger: homeassistant.components.sensor.recorder
Source: components/sensor/recorder.py:405
Integration: Sensor ([documentation](https://www.home-assistant.io/integrations/sensor), [issues](https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+sensor%22))
First occurred: June 20, 2023 at 10:05:15 (1 occurrences)
Last logged: June 20, 2023 at 10:05:15
The unit of sensor.plwgs_p1_pap_gas_consumed_interval (m³/h) cannot be converted to the unit of previously compiled statistics (m³). Generation of long term statistics will be suppressed unless the unit changes back to m³ or a compatible unit. Go to https://my.home-assistant.io/redirect/developer_statistics to fix this
Would like some help with this, anyone can give me a direction? Thanks.
