[Resolved] Harmony Hub issues after February 2019 update v.4.15.250
oh but how do i do that
Just remove the host from your config, as described here :
Or add the host field if you now did not configured it? How does your config look like now?
thanks for your repley this is what i did
discovery:
ignore:
enable:
- homekit
- logitech_mediaserver
HA found mine chromecast but not mine Harmony hub
And this mine config file
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Sensors
Weather prediction
  • platform: yr
Text to speech
tts:
  • platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
discovery:
ignore:
enable:
- homekit
Iam sorry i dont know how to get this smaller
You don’t have harmony in your config? Just add it like in the link I postef earlier
Mister Fabio Pergola
Thank you very much now i have a harmony config file
Now i can mess it up again :laughing: with something new
hey guys, I’m new here, coming from openHAB. they had the same issue with XMPP disabled. but meanwhile their integration changed to make use of “websockets” (whatever this means). is this not the case for home assistant?
