* Resolved! - Imported configuration for new setup - MQTT issues along with a lot of other issues
Long story short, made a mistake and wiped my Pi. Installed hassbian using latest image and I’m up and running again. However, the following is not working as intended:
Failed to load:
sensor.mqtt (also light.mqtt_json)
mqtt
tellduslive
I see the following in the log but I don’t know how to troubleshoot it further:
Setting up mqtt
2018-01-22 21:37:23 ERROR (MainThread) [homeassistant.setup] Error during setup of component mqtt
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py”, line 196, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/mqtt/init.py”, line 399, in async_setup
success = yield from hass.data[DATA_MQTT].async_connect()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/mqtt/init.py”, line 506, in async_connect
self._mqttc.connect, self.broker, self.port, self.keepalive)
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/srv/homeassistant/lib/python3.5/site-packages/paho/mqtt/client.py”, line 768, in connect
return self.reconnect()
File “/srv/homeassistant/lib/python3.5/site-packages/paho/mqtt/client.py”, line 895, in reconnect
sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
File “/usr/lib/python3.5/socket.py”, line 712, in create_connection
raise err
File “/usr/lib/python3.5/socket.py”, line 703, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
2018-01-22 21:37:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_call_id=1971990352-1, service_data=title=Invalid config, notification_id=invalid_config, message=The following components and platforms could not be set up:
Please check your config.>
2018-01-22 21:37:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=persistent_notification.invalid_config, new_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
Please check your config. @ 2018-01-22T22:37:23.390119+01:00>>
Any help is appreciated.
Without seeing any config, it’s hard to tell, but as it’s saying it refused to connect, then I would guess the broker isn’t running, your paswword is incorrect, your broker address is incorrect or your username is incorrect.
Thanks for responding! I was able to track it down, I was missing the Mosquitto MQTT server, forgot that I was using that instead of the embedded… silly me!
Case closed :slight_smile:
