Update: Problem is resolved. I had to use buinen radar sensor instead of the standard buienradar weather. This allowed me to point to the temp sensor. New and working config here:
- platform: buienradar
monitored_conditions:
- symbol
- humidity
- temperature
- windspeed
- pressure
- alias: Set Outside Temp
initial_state: true
platform: time_pattern
minutes: '/15'
- service: opentherm_gw.set_outside_temperature
data_template:
gateway_id: otgw
temperature: "{{ states('sensor.bussum_temperature')|float }}"
Hello gents,…this is my first post on the HA forum as I started with HA yesterday evening. Before HA I used to run domoticz but I’m reasonable done with. Im running a simple raspberry PI 3B with an Open Therm Gateway and a set of milights and of course buineradar for the Netherlands.
I already dealt with quirks of yaml,…especially the indentation requirements…what a pain…
im trying to get my first simple automation script running which is not working. The goal is to send the outside temperature to the Open Therm Gateway which will send it to the Isense thermostat allowing me to run thermostat setting requiring the OT.
Somehow it doesn’t work nut I dont get errors in the script.
Hoping on some adivse…
thx
Willem
default_config:
homeassistant:
latitude: 52.274140
longitude: 5.158630
unit_system: metric
time_zone: Europe/Amsterdam
light: !include lights.yaml
weather:
# Force 'Meetstation Bussum' to be used:
latitude: 52.274140
longitude: 5.158630
forecast: true
automations.yaml
initial_state: true
minutes: '/15'
data_template:
gateway_id: OTGW
temperature: "{{ states('weather.bussum') }}"
