Is anyone else having an issue connecting to the cloud integration? Mine started when 0.69 dropped, but there’s definitely a routing issue beyond my ISP. If I access a system I have in Grand Rapids, MI, it works fine, but I can’t route specific traffic through there on a permanent basis.
Routing issue appears to be on Amazon’s end as hop 6 in the below traceroute is the first IP outside my provider.
Mon May 14 2018 10:59:57 GMT-0300 (Atlantic Daylight Time)
Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:True [Connect call failed (‘52.86.247.137’, 8000)]
traceroute to cloud.hass.io (52.86.247.137), 30 hops max, 60 byte packets
1 gateway (Redacted) 0.319 ms 0.395 ms 0.456 ms
2 Redacted (Redacted) 10.577 ms 10.642 ms 10.552 ms
3 ae15-182.cr02.stjh.nb.aliant.net (142.176.208.41) 3.102 ms 3.118 ms 2.990 ms
4 be3-50.cr01.stjh.nb.aliant.net (142.166.181.109) 3.225 ms be5.bx01.nycm.ny.aliant.net (207.231.227.114) 18.868 ms 18.686 ms
5 be5.bx01.nycm.ny.aliant.net (207.231.227.114) 18.477 ms 18.407 ms 72.21.221.228 (72.21.221.228) 18.522 ms
6 52.93.4.115 (52.93.4.115) 23.137 ms 21.201 ms 72.21.221.228 (72.21.221.228) 20.769 ms
7 52.93.4.16 (52.93.4.16) 20.648 ms 52.93.4.109 (52.93.4.109) 25.287 ms 52.93.4.4 (52.93.4.4) 21.148 ms
8 * * 52.93.4.44 (52.93.4.44) 20.534 ms
9 * 54.239.44.218 (54.239.44.218) 23.336 ms 54.239.41.220 (54.239.41.220) 25.441 ms
10 * 54.239.42.186 (54.239.42.186) 23.078 ms 54.240.229.145 (54.240.229.145) 23.139 ms
11 54.239.111.150 (54.239.111.150) 38.243 ms * 54.239.111.146 (54.239.111.146) 35.124 ms
12 54.239.108.184 (54.239.108.184) 35.767 ms 54.239.108.252 (54.239.108.252) 43.907 ms 54.239.110.140 (54.239.110.140) 25.700 ms
13 54.239.110.130 (54.239.110.130) 25.596 ms 54.239.110.166 (54.239.110.166) 25.712 ms 54.239.110.183 (54.239.110.183) 34.493 ms
14 54.239.108.125 (54.239.108.125) 27.660 ms 54.239.110.169 (54.239.110.169) 40.995 ms 54.239.110.139 (54.239.110.139) 38.644 ms
15 54.239.109.5 (54.239.109.5) 24.751 ms 54.239.108.159 (54.239.108.159) 24.828 ms 24.799 ms
16 52.93.25.166 (52.93.25.166) 38.900 ms 52.93.25.135 (52.93.25.135) 23.974 ms 52.93.25.166 (52.93.25.166) 46.151 ms
17 * 52.93.25.159 (52.93.25.159) 23.014 ms 52.93.25.133 (52.93.25.133) 22.685 ms
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
telnet cloud.hass.io 8000
Trying 52.86.247.137…
telnet: connect to address 52.86.247.137: Connection timed out
