I have updated to 0.85.1 but the raw config editor still won’t save my resources
UPDATE: I actually just figured out the problem so I figured I’d post it here in case anyone else runs into the problem.
I never used Lovelace before this release so I never had a ui-lovelace.yaml file. I was using the auto-generate function and for some reason when I would try to add a resources section to the raw config it would not save no matter how many times I tried.
I got it to work by copying what was in the raw config editor already and then deleting the lovelace file from the .storage directory. then restarted HA but instead of auto-generating a new file I pasted the contents from the original raw config to the new raw config and it finally saved.
I have also update 0.85.1 but the problem is still there.
I did the same procedure that you did. The first time it worked but I needed to change something in the config and then the resources are deleted again.
I removed the lovelace file in the storage folder but when I did the same trick it is not working anymore.
