Resources problem
  1. element doesn’t exist: stack-in-card.
    in config yaml I have :
  resources:
    [     { url: /local/stack-in-card.js,                                                type: module
          { url: /local/vertical-stack-in-card.js?v=0.4.4,                               type: module },},
It is installed in HACS and found in www/community/stack-in-card
why isn’t it working ?
    1. element doesn’t exist: vertical-stack-in-card.
      same problem, same directory
  1. remove this from config yaml , if you installed through HACS it’s not needed ( beside the url’s are wrong )
  2. You should be able to see which cards/scripts are loaded in the Views, via the 3 dots in top-right corner, click, then click “edit” and again click “Resources” … there you should see the cards loaded, with urls like / hacsfiles / X-card / X-card.js … or if manually installed / local / x-card / x-card-js
So not only is your above url: wrong, it’s also not needed if you installed the cards through HACS, as the url then should be / hacsfiles / blabla / blabla.js
when I remove it all, its all custom element doesnt exist.
3dots and then config ui gives me that it is not possible in yaml mode, even if its changed in config.yaml to storage…
Sorry , i have no idea what you mean here, the whole sentence doesn’t make any sense to me.
I said, " In your VIEW (a view) click the 3 dots in top right corner( OF THE VIEW ) ( Not on some card ), then click EDIT, then click “MANAGE RESOURCES” , there you will see and can ADD the RIGHT url to your RESOURCES … which btw already should be correct if you installed it through HACS.
I don’t know where you got the idea of ALSO putting references in configuration.yaml ( AND beside wrong references / URL’s )
/ HACSFILES / MY-CARD / MY.CARD.JS ?hacstag=XXXXXXXXXXXX
PS: Do you have ANY CUSTOM cards , which you have installed through HACS, that works ?
PS2: You can also find “Resources” under /settings/Dashboards- 3-dots in top-right corner, of your screen.
You have to make sure that the custom:cards you install is there, AND that they have the correct url, to where you stored your custom-cards , usually this is /www/community/card-name/card.js
This location is also same as … /hacsfiles/card-name/card.js?hacstag=XXXXXXXXXXXX …or… /local/community/card-name/card.js
Thanks for your time. I will check it out
This was the solution. Thansk for your time and despite having a hard time with me , still helping me
hehe, yeah i think maybe we not have the same HA installation, and also when english is not our native language , it’s easy to misunderstand, and get frustrated :slight_smile:
again… sorry but thanks :wink:
