Especially using https with default 8123 port…
Just updated my main branch GitHub - formatBCE/Respeaker-Lite-ESPHome-integration
What’s changed:
- added sensor for installed DFU firmware version
- added software switch for microphone mute functionality
- Respeaker now is reset with ESP (was glitching before)
- added functionality from PE to stop the TTS with saying wake word.
Hmm I didnt so I tried updating it to what you have shown but then it gave me further error so I changed
media_player:
- platform: nabu
internal: false
sample_rate: 16000
i2s_dout_pin: GPIO43
bits_per_sample: 32bit
i2s_mode: secondary
i2s_audio_id: i2s_output
volume_increment: 0.05
volume_min: 0.4
volume_max: 0.85
to this
speaker:
- platform: i2s_audio
sample_rate: 16000
i2s_mode: secondary
dac_type: external
channel: left
media_player:
- platform: nabu
internal: false
audio_dac:
speaker:
sample_rate: 16000
volume_min: 0.4
volume_max: 0.85
then it complained again about audio_dac so I added the following but not sure if its right
audio_dac:
- platform: aic3204
INFO ESPHome 2024.10.1
INFO Reading configuration /config/esphome/respeaker.yaml...
INFO Updating https://github.com/esphome/voice-kit@dev
INFO Updating https://github.com/esphome/esphome.git@pull/7605/head
Failed config
audio_dac.aic3204: [source /config/esphome/respeaker.yaml:97]
Component audio_dac.aic3204 requires component i2c.
platform: aic3204
I think it needs this but wasnt sure of the GPIO’s being right…
i2c:
sda: GPIO5
scl: GPIO6
frequency: 400kHz
Update: Pins are good as per ReSpeaker Lite with XIAO ESP32S3 | The Pi Hut
In my repo you can find perfectly working config.
formatBCE
I think I had to go https when I set up Google Home and Alexa manually using duckdns. It was a few years ago!
ginandbacon:
I stripped it out and typed [MyURL] myself. It’s duckdns one and works both for external remote access and internally with NAT Loopback at the router.
I can access HA using the internal IP once I get through Chrome’s warning that it could be dangerous! EDIT Sorry, it has to be https://; using http:// does not get me access at all. I think I had to set up an http:// proxy to get my Ecowitt weather station working a while ago. Is that something I could use to overcome this issue? Ah, it looks like that was a special Ad-On just for the Ecowitt.
I could try to get ReSpeaker to use my internal HA IP if i knew how!
Here’s my redacted config. I should be as per the repo apart form my credential bits. Just noticed that I commented out the dns1 bit in the manual_ip block - could that be it?
substitutions:
voice_assist_idle_phase_id: "1"
voice_assist_listening_phase_id: "2"
voice_assist_thinking_phase_id: "3"
voice_assist_replying_phase_id: "4"
voice_assist_not_ready_phase_id: "10"
voice_assist_error_phase_id: "11"
voice_assist_muted_phase_id: "12"
esphome:
friendly_name: respeaker-satellite
min_version: 2024.9.0
platformio_options:
board_build.flash_mode: dio
on_boot:
priority: 600
then:
- script.execute: adjust_led
- delay: 30s
- if:
condition:
lambda: return id(init_in_progress);
then:
- lambda: id(init_in_progress) = false;
esp32:
board: esp32-s3-devkitc-1
variant: esp32s3
flash_size: 8MB
framework:
type: esp-idf
version: recommended
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_ESP32S3_INSTRUCTION_CACHE_32KB: "y"
CONFIG_ESP32_S3_BOX_BOARD: "y"
CONFIG_SPIRAM_ALLOW_STACK_EXTERNAL_MEMORY: "y"
CONFIG_SPIRAM_TRY_ALLOCATE_WIFI_LWIP: "y"
# Settings based on https://github.com/espressif/esp-adf/issues/297#issuecomment-783811702
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM: "16"
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM: "512"
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER: "y"
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE: "0"
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER_NUM: "8"
CONFIG_ESP32_WIFI_CACHE_TX_BUFFER_NUM: "32"
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED: "y"
CONFIG_ESP32_WIFI_TX_BA_WIN: "16"
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED: "y"
CONFIG_ESP32_WIFI_RX_BA_WIN: "32"
CONFIG_LWIP_MAX_ACTIVE_TCP: "16"
CONFIG_LWIP_MAX_LISTENING_TCP: "16"
CONFIG_TCP_MAXRTX: "12"
CONFIG_TCP_SYNMAXRTX: "6"
CONFIG_TCP_MSS: "1436"
CONFIG_TCP_MSL: "60000"
CONFIG_TCP_SND_BUF_DEFAULT: "65535"
CONFIG_TCP_WND_DEFAULT: "65535" # Adjusted from linked settings to avoid compilation error
CONFIG_TCP_RECVMBOX_SIZE: "512"
CONFIG_TCP_QUEUE_OOSEQ: "y"
CONFIG_TCP_OVERSIZE_MSS: "y"
CONFIG_LWIP_WND_SCALE: "y"
CONFIG_TCP_RCV_SCALE: "3"
CONFIG_LWIP_TCPIP_RECVMBOX_SIZE: "512"
CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST: "y"
CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY: "y"
psram:
mode: octal # quad for N8R2 and octal for N16R8
speed: 80MHz
external_components:
- source:
type: git
#url: https://github.com/esphome/voice-kit
#ref: dev
url: https://github.com/formatBCE/home-assistant-voice-pe
ref: format_bce
components:
- aic3204
- audio_dac
- media_player
- micro_wake_word
- microphone
- nabu
- nabu_microphone
- voice_assistant
- voice_kit
refresh: 0s
- source: github://pr#7605
components: [ audio, i2s_audio, speaker]
refresh: 0s
api:
encryption:
key: "REDACTED"
on_client_connected:
on_client_disconnected:
#ota:
# - platform: esphome
# id: ota_esphome
# password: !secret ota_password
logger:
wifi:
ap:
ssid: "Respeaker-Satellite-1"
password: "SDCi3ZeMJi3d"
on_connect:
on_disconnect:
ssid: "REDACTED"
manual_ip:
static_ip: REDACTED
gateway: REDACTED
subnet: REDACTED
# dns1: !secret dns1
captive_portal:
switch:
optimistic: true
internal: true
restore_mode: ALWAYS_OFF
on_turn_on:
# Duck audio
- nabu.set_ducking:
decibel_reduction: 20
duration: 0.0s
# Ring timer
- script.execute: ring_timer
# Refresh LED
# If 15 minutes have passed and the timer is still ringing, stop it.
- delay: 15min
- switch.turn_off: timer_ringing
on_turn_off:
# Stop any current annoucement (ie: stop the timer ring mid playback)
- if:
condition:
lambda: return id(nabu_media_player)->state == media_player::MediaPlayerState::MEDIA_PLAYER_STATE_ANNOUNCING;
then:
lambda: |-
->make_call()
.set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_STOP)
.set_announcement(true)
.perform();
# Set back ducking ratio to zero
- nabu.set_ducking:
decibel_reduction: 0
duration: 1.0s
# Refresh the LED ring
button:
# - platform: safe_mode
# id: button_safe_mode
# name: Safe Mode Boot
- platform: factory_reset
- platform: restart
binary_sensor:
- platform: gpio
pin:
number: GPIO4 # D3
inverted: true
- platform: gpio
pin:
number: GPIO3 # D2
inverted: true
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at least 0.25s
then:
- if:
condition:
lambda: return !id(init_in_progress);
then:
- if:
condition:
switch.is_on: timer_ringing
then:
else:
- if:
condition:
then:
- lambda: |
->make_call()
.perform();
else:
- if:
condition:
voice_assistant.is_running:
then:
- voice_assistant.stop:
else:
- if:
condition:
media_player.is_playing:
then:
- media_player.pause:
else:
- if:
condition:
and:
# - switch.is_off: master_mute_switch
- not:
then:
- voice_assistant.start:
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: GPIO1
num_leds: 1
rmt_channel: 0
chipset: ws2812
disabled_by_default: true
entity_category: config
default_transition_length: 0s
effects:
- pulse:
- pulse:
transition_length: 100ms
update_interval: 100ms
min_brightness: 50%
max_brightness: 100%
- pulse:
transition_length: 250ms
update_interval: 250ms
min_brightness: 50%
# Audio and Voice Assistant Config
i2s_audio:
- id: i2s_output
i2s_lrclk_pin:
number: GPIO7
allow_other_uses: true
i2s_bclk_pin:
number: GPIO8
i2s_mclk_pin:
number: GPIO9
- id: i2s_input
i2s_lrclk_pin:
number: GPIO7
i2s_bclk_pin:
number: GPIO8
i2s_mclk_pin:
number: GPIO9
microphone:
- platform: nabu_microphone
i2s_din_pin: GPIO44
adc_type: external
pdm: false
sample_rate: 16000
i2s_mode: secondary
i2s_audio_id: i2s_input
channel_0:
channel_1:
speaker:
sample_rate: 16000
i2s_mode: secondary
dac_type: external
channel: left
media_player:
- platform: nabu
internal: false
speaker:
sample_rate: 16000
volume_min: 0.4
volume_max: 0.85
on_announcement:
- nabu.set_ducking:
duration: 0.0s
on_state:
if:
condition:
and:
- switch.is_off: timer_ringing
- not:
- not:
then:
- nabu.set_ducking:
duration: 1.0s
micro_wake_word:
models:
- model: https://github.com/kahrendt/microWakeWord/releases/download/okay_nabu/okay_nabu.json
vad:
microphone: nabu_mic_mww
on_wake_word_detected:
# If a timer is ringing: Stop it, do not start the voice assistant (We can stop timer from voice!)
- if:
condition:
then:
# Start voice assistant, stop current announcement.
else:
- if:
condition:
then:
lambda: |-
->make_call()
.perform();
wake_word: !lambda return wake_word;
voice_assistant:
microphone: nabu_mic_va
media_player: nabu_media_player
noise_suppression_level: 0
auto_gain: 0dBFS
volume_multiplier: 1
- micro_wake_word.start:
- lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
- lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
on_error:
- if:
condition:
then:
- lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
- delay: 1s
on_start:
- nabu.set_ducking:
decibel_reduction: 20 # Number of dB quieter; higher implies more quiet, 0 implies full volume
duration: 0.0s # The duration of the transition (default is 0)
on_listening:
- lambda: id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
on_stt_vad_end:
- lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
on_tts_start:
- lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
on_end:
- wait_until:
not:
- nabu.set_ducking:
decibel_reduction: 0 # 0 dB means no reduction
duration: 1.0s
on_timer_finished:
- switch.turn_on: timer_ringing
script:
- id: ring_timer
then:
- while:
condition:
then:
- media_player.play_media: http://{ha_ip}:8123/local/sounds/timer_finished.flac
- delay: 1s
- wait_until:
not:
- id: adjust_led
then:
- if:
condition:
then:
- if:
condition:
then:
- light.turn_on:
red: 0%
green: 100%
blue: 0%
brightness: 60%
effect: fast pulse
else:
- if:
condition:
wifi.connected:
then:
- if:
condition:
api.connected:
then:
- lambda: |
switch(id(voice_assistant_phase)) {
case ${voice_assist_listening_phase_id}:
id(led_ww).turn_on()
.set_brightness(0.6)
.set_rgb(1.0, 0.2, 1.0)
.set_effect("Slow Pulse")
.perform();
break;
case ${voice_assist_thinking_phase_id}:
.set_effect("Fast Pulse")
.perform();
break;
case ${voice_assist_replying_phase_id}:
.set_rgb(0.2, 1.0, 1.0)
.perform();
break;
case ${voice_assist_error_phase_id}:
.set_rgb(1.0, 1.0, 0.2)
.perform();
break;
case ${voice_assist_muted_phase_id}:
.set_brightness(0.3)
.set_rgb(1.0, 0.0, 0.0)
.perform();
break;
case ${voice_assist_not_ready_phase_id}:
.perform();
break;
default:
id(led_ww).turn_off()
.perform();
else:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 40%
effect: fast pulse
else:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 40%
effect: slow pulse
else:
- light.turn_on:
red: 100%
green: 100%
blue: 0%
brightness: 30%
effect: slow pulse
globals:
- id: init_in_progress
type: bool
restore_value: false
initial_value: "true"
- id: voice_assistant_phase
type: int
initial_value: ${voice_assist_not_ready_phase_id}
Ran into strange issue, get a constant message about the state of the mute button not being detected. When I looked to see if there was new firmware, I noticed I was on 1.0.7. When I upgrade, it goes fine, but still lists as the same version. Anyone else have this issue? Outside the warning in the logs it works fine…
Running Ubuntu and added udev rule per Seed’s wiki and obviously upgraded
me@ubuntu:~$ sudo dfu-util -e -a 1 -D ffva_i2s_v1.0.8.bin
[sudo] password for me:
dfu-util 0.11
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Warning: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release
Opening DFU capable USB device...
Device ID 2886:0019
Device DFU version 0101
Claiming USB DFU Interface...
Setting Alternate Interface #1 ...
Determining device status...
DFU state(2) = dfuIDLE, status(0) = No error condition is present
DFU mode device DFU version 0101
Device returned transfer size 4096
Copying data from PC to DFU device
Download [=========================] 100% 270336 bytes
Download done.
DFU state(7) = dfuMANIFEST, status(0) = No error condition is present
Done!
me@ubuntu:~$ sudo dfu-util -l
dfu-util 0.11
Found DFU: [2886:0019] ver=0107, devnum=4, cfg=1, intf=0, path="3-1", alt=2, name="DFU DATAPARTITION", serial="0000000001"
Found DFU: [2886:0019] ver=0107, devnum=4, cfg=1, intf=0, path="3-1", alt=1, name="DFU UPGRADE", serial="0000000001"
Found DFU: [2886:0019] ver=0107, devnum=4, cfg=1, intf=0, path="3-1", alt=0, name="DFU FACTORY", serial="0000000001"
I think your config is fine. I think the main issue is it needs to connect via http on port 8123 over LAN and right now you can’t get to it internally. https wouldn’t work even with a valid SSL cert because it would still probably try to go out to the internet and back on port 8123, which isn’t open and shouldn’t be. Even then you would have https on 8123 which probably would be an issue. Need to get internal LAN access back.
Are you still using the proxy for external access? Just did a brief search here but found this , seems like installing a proxy disables http internal access, even once removed without clearing cache or other stuff.
Reconnect Respeaker to the PC, and run util.
Also, in my repo you can find 1.0.9.
Tried both, firmware update runs fine but version is 0107 after updating to either. According to Seeed’s wiki it should update. From wiki below… Really, really odd… I know it updated to 1.0.7 because it fixed my led issue. Nothing has changed. Going to try it on a friends Mac later but it’s an ARM version so who knows if dfu-util will even install.
EDIT: Everything works fine, just have this logged all the time. Just cleaned the build files too and installed again.
[17:55:23][W][respeaker_lite:069]: Read mic mute state failed [17:55:23][W][respeaker_lite:069]: Read mic mute state failed [17:55:23][W][respeaker_lite:069]: Read mic mute state failed [17:55:23][W][respeaker_lite:069]: Read mic mute state failed [17:55:23][W][respeaker_lite:069]: Read mic mute state failed [17:55:23][W][respeaker_lite:069]: Read mic mute state failed [17:55:23][W][respeaker_lite:069]: Read mic mute state failed [17:55:23][W][respeaker_lite:069]: Read mic mute state failed [17:55:23][W][respeaker_lite:069]: Read mic mute state failed [17:55:23][W]
Something wrong with the util?
Do you see version in Home Assistant?
Do you mean this one?
Currently have this flashed but its stopped working now
substitutions:
esphome:
friendly_name: respeakerv3
platformio_options:
on_boot:
priority: 600
then:
- delay: 30s
- if:
condition:
then:
esp32:
variant: esp32s3
flash_size: 8MB
framework:
type: esp-idf
sdkconfig_options:
psram:
speed: 80MHz
- source:
type: git
ref: dev
components:
- aic3204
- audio_dac
- media_player
- micro_wake_word
- microphone
- nabu
- nabu_microphone
- voice_assistant
- voice_kit
refresh: 0s
refresh: 0s
audio_dac:
- platform: aic3204
api:
encryption:
key: "removed"
ota:
- platform: esphome
password: "removed"
i2c:
sda: GPIO5
scl: GPIO6
frequency: 400kHz
logger:
wifi:
ssid: !secret wifi_ssid
on_connect:
on_disconnect:
#ssid: !secret wifi_ssid
#password: !secret wifi_password
#manual_ip:
# static_ip: !secret respeaker_satellite_1_ip
# gateway: !secret gateway
# subnet: !secret subnet
ap:
ssid: "Voice-Assistant Fallback Hotspot"
password: "removed"
captive_portal:
switch:
optimistic: true
internal: true
on_turn_on:
# Duck audio
- nabu.set_ducking:
duration: 0.0s
# Ring timer
# Refresh LED
- delay: 15min
on_turn_off:
- if:
condition:
then:
lambda: |-
->make_call()
.perform();
- nabu.set_ducking:
duration: 1.0s
button:
- platform: restart
binary_sensor:
- platform: gpio
pin:
number: GPIO4 # D3
inverted: true
- platform: gpio
pin:
number: GPIO3 # D2
inverted: true
on_multi_click:
- timing:
- ON for at most 1s
then:
- if:
condition:
then:
- if:
condition:
then:
else:
- if:
condition:
then:
- lambda: |
->make_call()
.perform();
else:
- if:
condition:
then:
else:
- if:
condition:
then:
else:
- if:
condition:
and:
- not:
then:
light:
rgb_order: GRB
pin: GPIO1
num_leds: 1
rmt_channel: 0
chipset: ws2812
effects:
- pulse:
- pulse:
min_brightness: 50%
- pulse:
min_brightness: 50%
i2s_audio:
- id: i2s_output
i2s_lrclk_pin:
number: GPIO7
i2s_bclk_pin:
number: GPIO8
i2s_mclk_pin:
number: GPIO9
- id: i2s_input
i2s_lrclk_pin:
number: GPIO7
i2s_bclk_pin:
number: GPIO8
i2s_mclk_pin:
number: GPIO9
microphone:
i2s_din_pin: GPIO44
adc_type: external
pdm: false
sample_rate: 16000
i2s_mode: secondary
channel_0:
channel_1:
speaker:
sample_rate: 16000
i2s_mode: secondary
dac_type: external
channel: left
media_player:
- platform: nabu
internal: false
audio_dac:
speaker:
sample_rate: 16000
volume_min: 0.4
volume_max: 0.85
on_announcement:
- nabu.set_ducking:
duration: 0.0s
on_state:
if:
condition:
and:
- not:
- not:
then:
- nabu.set_ducking:
duration: 1.0s
micro_wake_word:
models:
vad:
- if:
condition:
then:
else:
- if:
condition:
then:
lambda: |-
->make_call()
.perform();
voice_assistant:
auto_gain: 0dBFS
on_error:
- if:
condition:
then:
- delay: 1s
on_start:
- nabu.set_ducking:
on_listening:
on_stt_vad_end:
on_tts_start:
on_end:
- wait_until:
not:
- nabu.set_ducking:
duration: 1.0s
on_timer_finished:
script:
- id: ring_timer
then:
- while:
condition:
then:
- media_player.play_media: http://192.168.0.110:8123/local/sounds/timer-ding.mp3
- delay: 1s
- wait_until:
not:
- id: adjust_led
then:
- if:
condition:
then:
- if:
condition:
then:
- light.turn_on:
red: 0%
green: 100%
blue: 0%
brightness: 60%
effect: fast pulse
else:
- if:
condition:
wifi.connected:
then:
- if:
condition:
api.connected:
then:
- lambda: |
.perform();
break;
.perform();
break;
.perform();
break;
.perform();
break;
.perform();
break;
.perform();
break;
default:
.perform();
else:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 40%
effect: fast pulse
else:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 40%
effect: slow pulse
else:
- light.turn_on:
red: 100%
green: 100%
blue: 0%
brightness: 30%
effect: slow pulse
globals:
type: bool
type: int
Yup, the switch shows up, it just can’t detect the state. I did re-enable the binary sensor because I have an automation based on it. Trying to move it to the new assist_satellite domain…
That’s weird, probably something wrong with dfu util?
I mean this one GitHub - formatBCE/Respeaker-Lite-ESPHome-integration
The one you’re referring to is Home Assistant PE config and isn’t suitable for Respeaker Lite.
right got confused.
Also the respeaker_lite_i2s_dfu_firmware_v1.0.9.bin this is a new board firmware or esp firmware and I assume need to flash it?
This is the XMOS board hardware. There’s readme
flashed and check got this
D:\dfu-util\win64>dfu-util -e -a 1 -D respeaker_lite_i2s_dfu_firmware_v1.0.9.bin
dfu-util 0.11
Device ID 2886:0019
Run-Time device DFU version 0101
Download [=========================] 100% 315975 bytes
Download done.
Done!
D:\dfu-util\win64>dfu-util -l
dfu-util 0.11
Found DFU: [2886:0019] ver=0205, devnum=16, cfg=1, intf=3, path="1-1", alt=2, name="DFU DATAPARTITION", serial="0000000001"
Found DFU: [2886:0019] ver=0205, devnum=16, cfg=1, intf=3, path="1-1", alt=1, name="DFU UPGRADE", serial="0000000001"
Found DFU: [2886:0019] ver=0205, devnum=16, cfg=1, intf=3, path="1-1", alt=0, name="DFU FACTORY", serial="0000000001"
remove connect again and check
dfu-util 0.11
Found DFU: [2886:0019] ver=0105, devnum=64, cfg=1, intf=0, path="1-1", alt=2, name="DFU DATAPARTITION", serial="0000000001"
Found DFU: [2886:0019] ver=0105, devnum=64, cfg=1, intf=0, path="1-1", alt=1, name="DFU UPGRADE", serial="0000000001"
Found DFU: [2886:0019] ver=0105, devnum=64, cfg=1, intf=0, path="1-1", alt=0, name="DFU FACTORY", serial="0000000001"
Oh I am not having any luck with getting it working. Just randomly flashing red then yellow. I have used your repo with some changes to passwords etc
substitutions:
esphome:
platformio_options:
on_boot:
priority: 600
then:
- delay: 30s
- if:
condition:
then:
esp32:
variant: esp32s3
flash_size: 8MB
framework:
type: esp-idf
sdkconfig_options:
psram:
speed: 80MHz
- source:
type: git
ref: dev
#url: https://github.com/formatBCE/home-assistant-voice-pe
#ref: format_bce
components:
- aic3204
- audio_dac
- media_player
- micro_wake_word
- microphone
- nabu
- nabu_microphone
- voice_assistant
refresh: 0s
refresh: 0s
- source:
type: git
url: https://github.com/formatBCE/Respeaker-Lite-ESPHome-integration
ref: dev
components: [ respeaker_lite ]
refresh: 0s
api:
encryption:
key: "removed"
ota:
- platform: esphome
password: "removed"
logger:
wifi:
on_connect:
on_disconnect:
#manual_ip:
ap:
password: "removed"
captive_portal:
i2c:
- id: bus_a
sda: GPIO5
scl: GPIO6
scan: true
respeaker_lite:
i2c_id: bus_a
reset_pin: GPIO2
mute_state:
internal: true
firmware_version:
icon: mdi:application-cog
name: XMOS firmware version
internal: false
switch:
- platform: gpio
internal: true
pin:
number: GPIO4 # D3
inverted: true
on_turn_on:
- delay: 300ms
- switch.turn_off: mute_toggle
icon: mdi:microphone-off
lambda: |-
if (id(mute_state).state) {
return true;
} else {
return false;
turn_on_action:
- switch.turn_on: mute_toggle
turn_off_action:
optimistic: true
internal: true
on_turn_on:
# Duck audio
- nabu.set_ducking:
duration: 0.0s
# Ring timer
# Refresh LED
- delay: 15min
on_turn_off:
- if:
condition:
then:
lambda: |-
->make_call()
.perform();
- nabu.set_ducking:
duration: 1.0s
button:
- platform: restart
binary_sensor:
- platform: gpio
pin:
number: GPIO3 # D2
inverted: true
on_multi_click:
- timing:
- ON for at most 1s
then:
- if:
condition:
then:
- if:
condition:
then:
else:
- if:
condition:
then:
- lambda: |
->make_call()
.perform();
else:
- if:
condition:
then:
else:
- if:
condition:
then:
else:
- if:
condition:
and:
- not:
then:
light:
rgb_order: GRB
pin: GPIO1
num_leds: 1
rmt_channel: 0
chipset: ws2812
effects:
- pulse:
- pulse:
min_brightness: 50%
- pulse:
min_brightness: 50%
i2s_audio:
- id: i2s_output
i2s_lrclk_pin:
number: GPIO7
i2s_bclk_pin:
number: GPIO8
i2s_mclk_pin:
number: GPIO9
- id: i2s_input
i2s_lrclk_pin:
number: GPIO7
i2s_bclk_pin:
number: GPIO8
i2s_mclk_pin:
number: GPIO9
microphone:
i2s_din_pin: GPIO44
adc_type: external
pdm: false
sample_rate: 16000
i2s_mode: secondary
channel_0:
channel_1:
speaker:
sample_rate: 16000
i2s_mode: secondary
dac_type: external
channel: left
media_player:
- platform: nabu
internal: false
speaker:
sample_rate: 16000
volume_min: 0.0
volume_max: 1.0
on_announcement:
- nabu.set_ducking:
duration: 0.0s
on_state:
if:
condition:
and:
- not:
- not:
then:
- nabu.set_ducking:
duration: 1.0s
micro_wake_word:
models:
- model: okay_nabu
- model: https://github.com/kahrendt/microWakeWord/releases/download/stop/stop.json
internal: true
vad:
- if:
condition:
then:
else:
- if:
condition:
then:
lambda: |-
->make_call()
.perform();
voice_assistant:
auto_gain: 0dBFS
on_error:
- if:
condition:
then:
- delay: 1s
on_start:
- nabu.set_ducking:
on_listening:
on_stt_vad_end:
on_tts_start:
- script.execute: activate_stop_word_if_tts_step_is_long
on_end:
- wait_until:
not:
- nabu.set_ducking:
duration: 1.0s
- script.stop: activate_stop_word_if_tts_step_is_long
on_timer_finished:
script:
- id: ring_timer
then:
- while:
condition:
then:
- delay: 1s
- wait_until:
not:
# Script used activate the stop word if the TTS step is long.
# Why is this wrapped on a script?
# Becasue we want to stop the sequence if the TTS step is faster than that.
# This allows us to prevent having the deactivation of the stop word before its own activation.
- id: activate_stop_word_if_tts_step_is_long
then:
- delay: 1s
# Enable stop wake word
- lambda: id(stop).enable();
- id: adjust_led
then:
- if:
condition:
then:
- if:
condition:
then:
- light.turn_on:
red: 0%
green: 100%
blue: 0%
brightness: 60%
effect: fast pulse
else:
- if:
condition:
wifi.connected:
then:
- if:
condition:
api.connected:
then:
- lambda: |
.perform();
break;
.perform();
break;
.perform();
break;
.perform();
break;
.perform();
break;
.perform();
break;
default:
.perform();
else:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 40%
effect: fast pulse
else:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 40%
effect: slow pulse
else:
- light.turn_on:
red: 100%
green: 100%
blue: 0%
brightness: 30%
effect: slow pulse
globals:
type: bool
type: int
I’m pretty sure dfu util makes something wrong on Windows. You’re not the one reporting this. See, -l should report version 0109, not 0105, if you correctly downloaded the file.
yeah something not right. I managed to flash dfu-util -e -a 1 -D respeaker_lite_i2s_dfu_firmware_v1.0.8.bin
1.0.8 should work fine, if written correctly.
Make sure you clean build files in ESPHome before installing.
