I think something weird is going on…
INFO ESPHome 2024.10.1
INFO Reading configuration /config/esphome/respeaker.yaml...
INFO Updating https://github.com/esphome/voice-kit@dev
INFO Updating https://github.com/esphome/esphome.git@pull/7605/head
INFO Updating https://github.com/formatBCE/Respeaker-Lite-ESPHome-integration@dev
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Starting log output from respeaker-satellite.local using esphome API
WARNING Can't connect to ESPHome API for respeaker-satellite.local: Error resolving IP address: [Errno -5] No address associated with hostname (APIConnectionError)
INFO Trying to connect to respeaker-satellite.local in the background
INFO Successfully connected to respeaker-satellite @ 192.168.0.60 in 0.100s
INFO Successful handshake with respeaker-satellite @ 192.168.0.60 in 0.192s
[17:09:45][I][app:100]: ESPHome version 2024.10.1 compiled on Oct 23 2024, 15:28:36
[17:09:45][C][wifi:600]: WiFi:
[17:09:45][C][wifi:428]: Local MAC: 64:E8:33:50:C0:7C
[17:09:45][C][wifi:433]: SSID: [redacted]
[17:09:45][C][wifi:436]: IP Address: 192.168.0.60
[17:09:45][C][wifi:440]: BSSID: [redacted]
[17:09:45][C][wifi:441]: Hostname: 'respeaker-satellite'
[17:09:45][C][wifi:443]: Signal strength: -34 dB ▂▄▆█
[17:09:45][C][wifi:447]: Channel: 3
[17:09:45][C][wifi:448]: Subnet: 255.255.255.0
[17:09:45][C][wifi:449]: Gateway: 192.168.0.1
[17:09:45][C][wifi:450]: DNS1: 192.168.0.1
[17:09:45][C][wifi:451]: DNS2: 0.0.0.0
[17:09:45][C][logger:185]: Logger:
[17:09:45][C][logger:186]: Level: DEBUG
[17:09:45][C][logger:188]: Log Baud Rate: 115200
[17:09:45][C][logger:189]: Hardware UART: USB_SERIAL_JTAG
[17:09:45][C][i2c.idf:075]: I2C Bus:
[17:09:45][C][i2c.idf:076]: SDA Pin: GPIO5
[17:09:45][C][i2c.idf:077]: SCL Pin: GPIO6
[17:09:45][C][i2c.idf:078]: Frequency: 50000 Hz
[17:09:45][C][i2c.idf:084]: Recovery: bus successfully recovered
[17:09:45][I][i2c.idf:094]: Results from i2c bus scan:
[17:09:45][I][i2c.idf:100]: Found i2c device at address 0x18
[17:09:45][C][switch.gpio:068]: GPIO Switch 'mute_toggle'
[17:09:45][C][switch.gpio:091]: Restore Mode: always OFF
[17:09:45][C][switch.gpio:031]: Pin: GPIO4
[17:09:45][C][esp32_rmt_led_strip:187]: ESP32 RMT LED Strip:
[17:09:45][C][esp32_rmt_led_strip:188]: Pin: 1
[17:09:45][C][esp32_rmt_led_strip:189]: Channel: 0
[17:09:45][C][esp32_rmt_led_strip:214]: RGB Order: GRB
[17:09:45][C][esp32_rmt_led_strip:215]: Max refresh rate: 0
[17:09:45][C][esp32_rmt_led_strip:216]: Number of LEDs: 1
[17:09:45][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'User button'
[17:09:45][C][gpio.binary_sensor:016]: Pin: GPIO3
[17:09:46][C][light:103]: Light 'respeaker-satellite'
[17:09:46][C][light:105]: Default Transition Length: 0.0s
[17:09:46][C][light:106]: Gamma Correct: 2.80
[17:09:46][C][template.switch:068]: Template Switch 'Mic mute'
[17:09:46][C][template.switch:070]: Icon: 'mdi:microphone-off'
[17:09:46][C][template.switch:091]: Restore Mode: always OFF
[17:09:46][C][template.switch:057]: Optimistic: NO
[17:09:46][C][template.switch:068]: Template Switch 'timer_ringing'
[17:09:46][C][template.switch:057]: Optimistic: YES
[17:09:46][C][psram:020]: PSRAM:
[17:09:46][C][psram:021]: Available: YES
[17:09:46][C][psram:024]: Size: 8191 KB
[17:09:46][C][safe_mode.button:024]: Safe Mode Button 'Safe Mode Boot'
[17:09:46][C][safe_mode.button:024]: Icon: 'mdi:restart-alert'
[17:09:46][C][factory_reset.button:011]: Factory Reset Button 'Factory reset'
[17:09:46][C][factory_reset.button:011]: Icon: 'mdi:restart-alert'
[17:09:46][C][restart.button:017]: Restart Button 'Restart'
[17:09:46][C][restart.button:017]: Icon: 'mdi:restart'
[17:09:46][C][captive_portal:089]: Captive Portal:
[17:09:46][C][mdns:116]: mDNS:
[17:09:46][C][mdns:117]: Hostname: respeaker-satellite
[17:09:46][C][esphome.ota:073]: Over-The-Air updates:
[17:09:46][C][esphome.ota:074]: Address: respeaker-satellite.local:3232
[17:09:46][C][esphome.ota:075]: Version: 2
[17:09:46][C][esphome.ota:078]: Password configured
[17:09:46][C][safe_mode:018]: Safe Mode:
[17:09:46][C][safe_mode:020]: Boot considered successful after 60 seconds
[17:09:46][C][safe_mode:021]: Invoke after 10 boot attempts
[17:09:46][C][safe_mode:023]: Remain in safe mode for 300 seconds
[17:09:46][C][api:140]: API Server:
[17:09:46][C][api:141]: Address: respeaker-satellite.local:6053
[17:09:46][C][api:143]: Using noise encryption: YES
[17:09:46][C][micro_wake_word:072]: microWakeWord:
[17:09:46][C][micro_wake_word:073]: models:
[17:09:46][C][micro_wake_word:015]: - Wake Word: Okay Nabu
[17:09:46][C][micro_wake_word:016]: Probability cutoff: 0.97
[17:09:46][C][micro_wake_word:017]: Sliding window size: 5
[17:09:46][C][micro_wake_word:015]: - Wake Word: Stop
[17:09:46][C][micro_wake_word:016]: Probability cutoff: 0.50
[17:09:46][C][micro_wake_word:021]: - VAD Model
[17:09:46][C][micro_wake_word:022]: Probability cutoff: 0.50
[17:09:46][C][micro_wake_word:023]: Sliding window size: 5
[17:09:46][D][micro_wake_word:379]: Starting wake word detection
[17:09:46][D][light:036]: 'respeaker-satellite' Setting:
[17:09:46][D][light:047]: State: OFF
[17:09:46][D][light:109]: Effect: 'None'
[17:09:46][D][esp-idf:000][microphone_task]: I (75732) I2S: DMA Malloc info, datalen=blocksize=1280, dma_buf_count=4
[17:09:47][D][i2s_audio.microphone:377]: Starting I2S Audio Microphne
[17:09:47][D][i2s_audio.microphone:381]: Started I2S Audio Microphone
[17:09:47][D][micro_wake_word:418]: State changed from IDLE to DETECTING_WAKE_WORD
[17:14:47][D][micro_wake_word:357]: Detected 'Okay Nabu' with sliding average probability is 0.99 and max probability is 1.00
[17:14:47][D][voice_assistant:516]: State changed from IDLE to START_MICROPHONE
[17:14:47][D][voice_assistant:522]: Desired state set to START_PIPELINE
[17:14:47][D][voice_assistant:225]: Starting Microphone
[17:14:47][D][ring_buffer:034]: Created ring buffer with size 16384
[17:14:47][D][voice_assistant:516]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[17:14:47][D][voice_assistant:516]: State changed from STARTING_MICROPHONE to START_PIPELINE
[17:14:47][D][voice_assistant:280]: Requesting start...
[17:14:47][D][voice_assistant:516]: State changed from START_PIPELINE to STARTING_PIPELINE
[17:14:47][W][respeaker_lite:063]: Request mic mute state failed
WARNING respeaker-satellite @ 192.168.0.60: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for respeaker-satellite @ 192.168.0.60
WARNING Disconnected from API
INFO Successfully connected to respeaker-satellite @ 192.168.0.60 in 0.495s
INFO Successful handshake with respeaker-satellite @ 192.168.0.60 in 0.222s
