Response_variable
I am trying to use a response_variable in an automation but I do not seem able to make it work. Automation Code:
actions:
  - action: script.ground_temperature_ok_2
    metadata: {}
      home_presence: "{{ home_presence }}"
      manual_control: "{{ manual_temperature_control }}"
      manual_temperature: "{{ manual_temperature }}"
      comfort_target: 17
      eco_target: 15
      climate_mode: "{{ climate_mode }}"
      current_temperature: "{{ climate_measurement }}"
      climate_entity: "{{ climate_entity }}"
    response_variable: result
  - choose:
    - conditions:
      - condition: state
        entity_id: !input climate_mode
        state: 'Off'
      - condition: template
        value_template: |
          {{ states(climate_entity) != 'off' or not is_state_attr(climate_entity, 'fan_mode', states(fan_mode)) or not is_state_attr(climate_entity, 'swing_mode', states(vertical_swing_mode)) }}
      sequence:
        - action: script.ground_hvac_heat
          metadata: {}
            fan_mode: "{{ fan_mode }}"
            vertical_swing_mode: "{{ vertical_swing_mode }}"
            horizontal_swing_mode: "{{ horizontal_swing_mode }}"
        - action: script.ground_hvac_off
          metadata: {}
          data: {}
    - conditions:
      - condition: state
        entity_id: !input manual_temperature_control
        state: 'on'
      sequence:
        - choose:
            - conditions:
              - condition: state
                state: "Heating"
              sequence:
                - choose:
                    - conditions:
                          value_template: result.hvac_needed
                        - condition: not
                          conditions:
                            - condition: state
                              entity_id: !input climate_entity
                              state: "heat"
                      sequence:
                          metadata: {}
                    - conditions:
                        - condition: not
                          conditions:
                            - condition: state
                              state: "off"
                      sequence:
                          metadata: {}
                          data: {}
and the called script
alias: Ground Temperature OK
variables:
  result: >
    {% set target = comfort_target | float %}
    {% if not states(home_presence) == 'on' %}
      {% set target = eco_target | float %}
    {% endif %}
    {% if states(manual_control) == 'on' %}
      {% set target = states(manual_temperature) | float %}
    {% endif %}
    {% set air_conditioning_needed = false %} {% set hvac_mode =
    states(climate_mode) %}
    {% if hvac_mode == 'Heating' %}
      {% if states(current_temperature) | float < (target - 0.5) or states(climate_entity) == 'heat' %}
        {% set air_conditioning_needed = true %}
      {% endif %}
      {% if states(current_temperature) | float > target %}
      {% endif %}
    {% endif %}
    {% if hvac_mode == 'Cooling' %}
      {% if states(current_temperature) | float > (target + 0.5) or states(climate_entity) == 'cool' %}
      {% endif %}
      {% if states(current_temperature) | float < target %}
      {% endif %}
    {% endif %}
    {{ {'hvac_needed': air_conditioning_needed} }}
sequence:
  - stop: All Done
mode: single
I do not seem to be able to read the boolean answer in result.hvac_needed ion the automation.
Please post the entire automation. There are some uses of !input that look odd, but it is impossible to tell seeing only the actions block.
This is definitely incorrect:
It needs to be surrounded in quotes (or preceded by a block scalar identifier) as well as the appropriate Jinja delimiters:
   value_template: "{{ result.hvac_needed }}"
I am having no issues with the !input, they all work as expected.
I have change the condition to:
                          conditions:
                              value_template: >
which appears to be working for me at the moment.
Thanks for your reply
