Need to send authorisation token of the below mentioned REST Api with this token Dzca0UFcPZ1SCih9dL1zPx2PtKUCpLaUyNyeZW7ko1Y (This is Long Live Token generated from Home Assistant).
Possible to send the authorisation token with the above URL in a single command? what would be the syntax of this command need to execute this command on the browser.
I have ten such commands, need to execute them from a single click on the browser.
Are you using some kind of framework like React? Do you want to do all this purely from the client side? You could look into pure JavaScript fetch, but that is very limited, and you might run into CORS issues.
Sorry, I’m not using Node-RED myself. A quick search came up with this guide that shows how you can specify an HTTP command and it has a section about how to set a HTTP request header which is what you need.
