Hello everyone
Hope you are fine during this strange time.
I’m trying to call home assistant through a curl command.
The script I try to call is “Ampli”, it helps me using a Broadlink RM4C Mini to send a command to my Denon Amplifier.
Here is my script.
curl -X POST -H "Authorization: Bearer mytoken" -H "Content-Type: application/json" -d "{ \"entity_id\": \"script.Ampli\" }" http://192.168.1.2:8123/api/services/script/Ampli
I get the error “400: Bad Request”, do you have any idea what could provoke this error ?
Manu
TazUk
(Taz Uk)
May 10, 2020, 5:47pm
2
Authorisation should be by access token not password - RestAPI
Of course I use access token, I just replaced it in my exemple by the word “password”
tmjpugh
(Tmjpugh)
May 11, 2020, 8:08am
4
“Authorization: bearer yourtoken”
EDIT
B is capital
“Authorization: Bearer yourtoken”
Yes I got this from the documentation and it’s ok already.
The “bad request” error is coming from something else…
Thank you for your help
TazUk
(Taz Uk)
May 11, 2020, 8:43am
6
I’ve just tested turning a light on using:
curl -X POST -H 'Authorization: Bearer <longtoken>' -H 'Content-Type: application/json' -d '{"entity_id": "switch.kitchen_lamp_switch"}' http://192.168.1.x:8123/api/services/switch/turn_on
which works fine here.
May not be root cause, but look at your nested quotes for the data section and compare with above.
I will give more testings this afternoon.
When I take a look to your example, I think there’s something wrong with my API URL.
My URL: http://192.168.1.2:8123/api/services/script/Ampli (“Ampli” is the name of the script I created)
Maybe it should be only http://192.168.1.2:8123/api/services/script/ as the entity id refers already to the specific script I want to call (“Ampli”)
In fact I’m not clear what’s expected by Home Assistant as URL& Entity ID to call a script.
tmjpugh
(Tmjpugh)
May 11, 2020, 9:05am
8
look at Developer Tools>>Services page in your homeassistant.
you need to call a valid service available there. I dont use scripts so I not sure what is valid service to call script but you may look there to verify.
i did find strange you get 404 for bad password. I think you still wrong format password however.
OK you’re right I will try to call the service directly and skip the script part even if my script executes perfectly from Home Assistant UI.
TazUk
(Taz Uk)
May 11, 2020, 9:15am
10
Off the top of my head, you probably want something like:
curl -X POST -H 'Authorization: Bearer mytoken' -H 'Content-Type: application/json' -d '{"entity_id': "script.Ampli"}' http://192.168.1.2:8123/api/services/script/turn_on
Thanks TazUK, this is much better now with the URL you suggested.
curl -X POST -H "Authorization: Bearer Mytoken" -H "Content-Type: application/json" -d "{ \"entity_id\": \"script.Ampli\" }" http://192.168.1.2:8123/api/services/script/turn_on
Now curl command executes without error but my Ampli script is not executed.
After checking logs in Home Assistant UI I see that.
Logger: homeassistant.helpers.service
Source: helpers/service.py:189
First occurred: 16:07:13 (2 occurrences)
Last logged: 16:07:25
Unable to find referenced entities script.ampli
Probably the entity id is not good now.
EDIT: Ok I get it now…I must use the numeric identifier of my script (I got it in scripts.yaml configuration file).
Good syntax now is
curl -X POST -H "Authorization: Bearer Mytoken" -H "Content-Type: application/json" -d "{ \"entity_id\": \"script.1589020271119\" }" http://192.168.1.2:8123/api/services/script/turn_on
Works like a charm !!!
Thank you! Your example helped me finding out this out for the last week.
