Hello
It seems like the history through the rest api not always contain the latest state of an input_number?
I try to get the history of the last few hours, here it’s a quite newly created input_number.
I’m first reading out the current time of home assistant and use it in the history request (here code is in octave/matlab).
% get latest time from home assistant (to avoid timezone/utc crap)
url=strcat('http://',address_hass,'/api/states/sensor.date_time_iso');
options = weboptions('HeaderFields',{'Authorization' ['Bearer ' auth_token]});
full_url = [url, "&minimal_response"];
data = webread(url, options);
if isempty(data)
entity_data='error';
hass_time='Failed to get time from Home Assistant';
most_recent_states='error';
return
end
data = jsondecode(data);
hass_time = data.state;
% get actual data from entity
base_url = strcat("http://",address_hass,"/api/history/period/");
end_time = hass_time;
t = parse_timestamp(hass_time);
start_time=datestr(t-hours_of_data/24, 'yyyy-mm-ddTHH:MM:SS');
encoded_end_time= urlencode(end_time);
encoded_start_time = urlencode(start_time);
full_url = [base_url, encoded_start_time,"?end_time=", encoded_end_time, "&filter_entity_id=", entity_id,"&minimal_response"];
data = webread(full_url, options);
full_url in this exapmle would result in:
http://192.168.0.205:8123/api/history/period/2025-01-06T20%3A31%3A00?end_time=2025-01-06T21%3A31%3A00&filter_entity_id=input_number.tgttempbedroom&minimal_response
However data returns empty, also the specific entity in home assistant says there is no history
full_url='http://192.168.0.205:8123/api/states/input_number.tgttempbedroom'
Here the data gives a value as expected
data = {"entity_id":"input_number.tgttempbedroom","state":"8","attributes":{},"last_changed":"2025-01-06T19:55:10.384827+00:00","last_updated":"2025-01-06T19:55:10.384827+00:00","context":{"id":"01JGYJYZNG2218RQVG4ZVY2TCW","parent_id":null,"user_id":"3aad81cb0e584496a5741a371070a0ea"}}
