Hi Guys,
I hope you can help me out. Its driving me nuts. Spending already 2 days solving this.
I have many z-wave dimmers added into homeassistant.
They appear in 2 ways in the overview menu. As a switch and as a light item.
Now I try to use the API to turn them off and on but It seems that the command is correctly accepted by HA but I get a 404 that the entity can not be found.
For example, I have a z-wave dimmer and I named it ‘1e_boekenwand_m’
It appears in the overview as to items, light and switch. When I click on them I get:
Light:
node id 16
value id some long number
new entity id: light.1e_boekenwand_m_level
old entity id: light.1e_boekenwand_m_level_16_0
Switch:
node id 16
new identity id: switch.1e_boekenwand_m_switch
old identity id: switch.1e_boekenwand_m_switch_16_0
Now I want to use the API to switch them on and off but I cant get it to work.
I use for instance
wget -O - ‘http://192.168.0.171:8123/api/states/switch.1e_boekenwand_m_switch_16_0?api_password=secret’
or
wget -O - ‘http://192.168.0.171:8123/api/states/switch.1e_boekenwand_m_switch?api_password=secret’
but all I get is
018-09-07 10:25:19 ERROR 404: Not Found.
Also both light entity’s don’t work. Whichever entity I tried I always get the 404 error.
I do have another light entry which I manually added ‘switch.zoutlamp’ and that one works perfectly through the API but that one is not a z-wave device.
wget -O - 192.168.0.171:8123/api/states/switch.zoutlamp?api_password=secret’ --2018-09-07 14:04:36–
Connecting to 192.168.0.171:8123… connected.
HTTP request sent, awaiting response… 200 OK
Length: 197 [application/json]
Saving to: ‘STDOUT’
0%[ ] 0 --.-KB/s {"attributes": {"friendly_name": "zoutlamp"}, "entity_id": "switch.zoutlamp", "last_changed": "2018-09-06T19:42:54.1471- 100%[===============================================>] 197 --.-KB/s in 0s
2018-09-07 14:04:36 (23.4 MB/s) - written to stdout [197/197]
Does somebody know how to address these dimmers through the API? I am lost!
Cheers
Maarten
