I have a C++ client that makes use of the REST API by the curl library.
99% of the time I use GET or SET (using the ID such as sun.sun) it works fine. I can retrieve data, I can switch on and off devices.
That remaining 1% fails with curl error 7 i.e. CURLE_COULDNT_CONNECT
Any ideas as to the root cause ? should I try the request again ?
Regards,
Andrew
