I’m new to the forum and have a problem/question. I’d like to save the content of a REST API into a state, similar how team tracker plugin. I set up the following sensor in configuration.yaml:
- platform: rest
unique_id: bund1_table
scan_interval: 3600
resource: https://site.web.api.espn.com/apis/v2/sports/soccer/ger.1/standings?type=0&level=0&lang=de
value_template: "{{ now() }}"
json_attributes_path: "$['children'][0]['standings']"
json_attributes:
- entries
- platform: rest
unique_id: bund3_table
scan_interval: 3600
resource: https://api.openligadb.de/getbltable/bl3/2025
json_attributes_path: "$"
json_attributes:
"bund3_table" isn't working, but "bund1_table" not. They are different addresses, Can anyone help me for "bund3_table" to make it work?
koying
(Chris B)
June 14, 2026, 1:16pm
2
What information are you looking for from bund3?
All Informations from the api/json to display the table from the ligue
koying
(Chris B)
June 14, 2026, 5:44pm
4
Looks like grabbing a list as an attribute directly with a rest sensor is not possible.
You could use a command_line sensor with a curl to achieve this.
Idea is to transform the output into something like:
"result": [
"teamInfoId": 36,
"teamName": "VfL Osnabrück",
"shortName": "Osnabrück",
"teamIconUrl": "https://upload.wikimedia.org/wikipedia/commons/thumb/4/4e/VfL_Osnabrueck_Logo_2021%E2%80%93.svg/960px-VfL_Osnabrueck_Logo_2021%E2%80%93.svg.png",
"points": 80,
"opponentGoals": 34,
"goals": 66,
"matches": 38,
"won": 24,
"lost": 6,
"draw": 8,
"goalDiff": 32
"teamInfoId": 93,
to be able to do
json_attributes:
- result
Thank for your reply. Why does a rest not work? With the other is work fine. How must/can a command line sensor work?
koying
(Chris B)
June 15, 2026, 7:39am
6
Because, as you noticed, the resulting json is an array at root, and, according to what I get from the actual code, this is not handled by HA. HA wants a dictionary as a result from the json_attributes_path from which it can extract the attributes.
Ok, that a shame to hear this. And how can i managed with command line?
koying
(Chris B)
June 15, 2026, 12:29pm
8
Use this command to generate the json as outlined above:
curl https://api.openligadb.de/getbltable/bl3/2025 | jq '{ result: . }'
I add this to my configuration, It is right? But the state is empty. In ssh it is work.
command_line:
- sensor:
scan_interval: 3600
icon: "mdi:soccer"
command: >-
curl "https://api.openligadb.de/getbltable/bl3/2025" | jq '{ result: . }'
command_timeout: 30
koying
(Chris B)
June 15, 2026, 2:34pm
10
Add
json_attributes:
- result
Thank you. That work for me
Have you please an ideo to display the position/number of the array, when i use the flex-table-card?
type: custom:flex-table-card
entities:
include: sensor.bund3_table
columns:
- name: Place
data: result
modify: x.???
- name: Team
data: result
modify: x.teamName
- name: P
data: result
modify: x.points
strict: true
css:
tbody td:nth-child(8)+: "width: 40px;"
in the column "Place" the position in the array, also 1,2,3...
Does anyone have an idea how to display only the entry's position as information? Here is the requirement:
Pl Team P
1 BVB 78
2 FCK 75
3 FCB 73
4 BMG 69
The values are in the array only the Pl(Place) is missing.
koying
(Chris B)
June 17, 2026, 1:21pm
15
use :
curl https://api.openligadb.de/getbltable/bl3/2025 | jq '[sort_by(.points) | reverse | to_entries[] | {rank: (.key + 1)} + .value] | { result: . }'
to sort the array and add the indesx (as rank).
Thanks Claude for the syntax
