Rest command api ? optimalisation
hello ,
i control my wled brightness directly via tha wled api
i use this , but i suppose this code is not optimal when i use much bigger API’s
can this code be optimalised or is tis 100% the way to go ?
thanks for your reply :slight_smile:
config.yaml :
rest_command:
  restwled_felheid:
    url: "http://192.168.1.172/win&A={{states('input_number.wled_felheid') }}"
    method: get
    content_type: "application/json"
automatisation :
alias: rest
description: ""
  - platform: state
    entity_id:
      - input_number.wled_felheid
condition: []
  - action: rest_command.restwled_felheid
    metadata: {}
    data: {}
mode: single
Is there a reason you’re not just using the WLED integration in core?
2 reasons : first the wled-api is for me a testcase to learn programming restcommands
secondly : wled has no direct setting so change the brightness easyly , ( the ha core uses wled on and brightness as attribute )
ontopic , is my code/approch a go or nogo ?
kind regards ,
