Hi, I try to add a rest command to send a command from one HA to HA. I need to fill an input_text from a notifier. Andonly way I found is by using rest as notifier and send the text via rest to my input_text field. But I can not get It working, here is my actual config
rest_command:
fake_notify:
url: http://localhost:8123/api/services/input_text/set_value
method: POST
headers:
Authorization: 'Bearer eyJ0eXAi---changed-for-sharing---YbUgbxuNaK19zp26ztSgllAgDHGw'
Content-Type: 'application/json'
payload: '{"entity_id": "input_text.message_module","value": "{{ value }}"}}'
Maybe headers are not correct or something not sure. Using a shell command with curl for a similar thing to control HA from outside so authorisation key is correct and working.
Hope you have an idea why it is not working.
